duplicate channels shown in TV Guide
Hi,
I have a minor issue with the TV guide shown within Emby, both web and iOS app.
Each TV channel is shown twice. The first row per channel has full program data, the second is blank. I'd like to get rid of the duplicates if I can. In addition, a few channels only have one row shown, but unfortunately this is the blank one.
My setup is an HdHomeRun TV tuner, NextPVR configured to load the channels, pull the EPG data and schedule recordings, and Emby server with the NextPVR plugin. NextPVR and Emby are running on the same box.
The NextPVR GUI shows a correct Guide, so I guess the problem is somewhere in the configuration of the plugin or LiveTV section of Emby.
This is in the UK, so it's OTA channels, not cable.
Has anyone seen something similar, or have any suggestions?
thanks
Stephen
Can you add some logging?
I am also having this problem.  Duplicate channels for every channel I have.  Duplicates are only in the emby plugin.  In nextpvr it is normal.  I hope this is the log you need.
Any help is appreciated.
serverlog.txt
Edited by mh272
