Solution ebr 16332 Posted September 29, 2016 Solution Posted September 29, 2016 Does your ImagesByName folder have a subfolder called "metadata"? 1
moviefan 187 Posted September 29, 2016 Author Posted September 29, 2016 Yes it does. And it didn't even have a General folder inside of it but I just created one and moved Movies By Genre folder to it and it is working once again. Thank you!
ebr 16332 Posted September 30, 2016 Posted September 30, 2016 If you also had People data directly under that folder, make sure you merge it with what is now under "metadata" as that is where the server is looking now.
moviefan 187 Posted September 30, 2016 Author Posted September 30, 2016 Ok I am going to do this. So just so I understand - all of the rest of the folders I have under ImagesByName that are not underneath metadata are no longer doing anything?
ebr 16332 Posted September 30, 2016 Posted September 30, 2016 Ok I am going to do this. So just so I understand - all of the rest of the folders I have under ImagesByName that are not underneath metadata are no longer doing anything? Correct. Just move/merge them into the metadata subfolder.
