[FR] Advanced options for MP4 conversion
I'd like to see a way to modify some advanced options for the MP4 conversion.  Even if that means editing a config file somewhere vs. editing in the UI.
Things that come to mind:
  • Max dimensions for conditional downscaling
  • Yadif deinterlace type - x1 or x2 (double the frame rate)
  • Acceptable audio types and channel layouts for copying the codec, and a target transcoding type if audio transcoding is needed.
Bonus points if given a way for those familiar with FFMPEG options to be able to define the full commandline used.
It might be nice to have some sort of profile system to define different sets of options.  When editing a recording setup, can choose between the different profiles for different recordings.
