Tranquil 95 Posted February 19, 2016 Posted February 19, 2016 Hello Forum. Not a real bug, but I noticed during complete sync, it is much faster if I keep staying in the settings menu as in the home menu. Nearly by a factor of 100%. Using Titan theme. My complete library now syncs in less then 15 minutes where it took more the 30 before (Same version).
xnappo 1611 Posted February 19, 2016 Posted February 19, 2016 That is interesting. I wonder if the nextup widgets etc are constantly looking for updates if you are on the home screen slowing it down.. 1
xnappo 1611 Posted February 19, 2016 Posted February 19, 2016 (edited) If you don't mind testing - could you try doing the sync with Confluence as the active skin and comparing? Edited February 19, 2016 by xnappo 1
Angelblue05 4132 Posted February 19, 2016 Posted February 19, 2016 Reading my mind xnappo Sent from my iPhone using Tapatalk
spootdev 56 Posted February 19, 2016 Posted February 19, 2016 My install does the same thing with stock skin.
dubs 1 Posted February 19, 2016 Posted February 19, 2016 Just tried this on the device I've been having trouble with in the other thread (given it only does a couple of movies/episodes second at most, any speed increase should be quite noticeable). Using my scientific method of how long it took to do 30 movies: Kodi Homepage - 34 seconds. Kodi Settings - 24 seconds Definitely seems to be faster, Kodi 15.2 using Confluence skin
spootdev 56 Posted February 19, 2016 Posted February 19, 2016 Oh yeah, Kodi 15.1 stock skin on Xubuntu w/xfce. I just assumed Kodi is doing dumb things.
marcelveldt 736 Posted February 19, 2016 Posted February 19, 2016 That is interesting. I wonder if the nextup widgets etc are constantly looking for updates if you are on the home screen slowing it down..No, they should only update after the db commit. I think kodi is throttling something?
Tranquil 95 Posted February 19, 2016 Author Posted February 19, 2016 Same library: 13:39 minutes with confluence. Doesn't matter which menu I opened. All the nearly same speed. So it's a titan thing. Maybe a thread blocking shared Ressource!? Gesendet von meinem SM-G925F mit Tapatalk
Angelblue05 4132 Posted February 19, 2016 Posted February 19, 2016 In Aeon Nox, I do not see a difference between syncing while on home screen vs settings screen. Takes 3min 26 seconds in both cases.
