Fratopolis 64 Posted February 19, 2016 Posted February 19, 2016 (edited) Ok if your Kodi (Openelec) is crashing during an initial sync I have found a workaround. -Load OpenElec x86 on a laptop or desktop. -Then setup emby addon the way you want it. -Once sync is complete and everything is working run an openelec backup and restore the backup on your pi. The incremental syncs work fine after that. It seems to be just that first sync it does not like. I have done this numerous times and works great. ENJOY Edited February 19, 2016 by Fratopolis
Angelblue05 4132 Posted February 19, 2016 Posted February 19, 2016 (edited) The fix is already added to stable. The crash is caused by hammering the Kodi api while importing artwork. This issue seems specific to rpi devices only. To fix the crash, just limit the artwork cache thread to 25 in the add-on settings > sync options as already stated here: http://emby.media/community/index.php?/topic/21888-emby-for-kodi-10-liv/?p=301909 Edited February 19, 2016 by Angelblue05
Fratopolis 64 Posted February 19, 2016 Author Posted February 19, 2016 Well SOB ughhhh wish I saw this haha 1
Angelblue05 4132 Posted February 19, 2016 Posted February 19, 2016 (edited) Heheh Well now you know (I just made it in bold so people can see it better). When we will rework the initial set up, I will add a prompt for this, so you can enable it before the initial sync starts. Edited February 19, 2016 by Angelblue05 1
xnappo 1611 Posted February 19, 2016 Posted February 19, 2016 Maybe we can query the processor type and set it to 25 for ARM.
CBers 7554 Posted February 19, 2016 Posted February 19, 2016 Maybe we can query the processor type and set it to 25 for ARM. Or the OS. Seems to work fine without changing anything with OSMC on a RPi/RPi2. I'm sure @@scalda will confirm.
scalda 69 Posted February 19, 2016 Posted February 19, 2016 Or the OS. Seems to work fine without changing anything with OSMC on a RPi/RPi2. I'm sure @@scalda will confirm. I can confirm that osmc on all of my pis (3 pi 1's & 1 pi 2) doesn't have any problems with default settings for syncing 1
marcelveldt 736 Posted February 19, 2016 Posted February 19, 2016 Maybe we can query the processor type and set it to 25 for ARM.Even better kodi has an infolabel to inform the system is a pi
Angelblue05 4132 Posted February 19, 2016 Posted February 19, 2016 (edited) Yes, I wanted to make it display the dialog during the initial setup based on that fact. However, since this particular info label is not very "precise", it's better to let the user decide to enable the setting or not. I think kodi returns anything linux as linux/rpi. So it's not rpi specific, but better than nothing. Edited February 19, 2016 by Angelblue05
