Possible bug with audio selection
General
Unique ID                      : 121985501731725535187587201329774134812 (0x5BC58D951E6D257AAE59649BC43F061C)
Complete name                  : F:\Movies\Brave (2012)\Brave (2012).mkv
Format                         : Matroska
Format version                 : Version 4 / Version 2
File size                      : 9.23 GiB
Duration                       : 1h 33mn
Overall bit rate mode          : Variable
Overall bit rate               : 14.1 Mbps
Movie name                     : Brave
Writing application            : Lavf57.23.100
Writing library                : Lavf57.23.100
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4
Format settings, CABAC         : Yes
Format settings, ReFrames      : 4 frames
Codec ID                       : V_MPEG4/ISO/AVC
Duration                       : 1h 33mn
Width                          : 1 920 pixels
Height                         : 800 pixels
Display aspect ratio           : 2.40:1
Frame rate mode                : Constant
Frame rate                     : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Writing library                : x264 core 133 r2334 a3ac64b
Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                       : English
Default                        : No
Forced                         : No
DURATION                       : 01:33:37.194000000
Audio #1
Format                         : TrueHD
Codec ID                       : A_TRUEHD
Duration                       : 1h 33mn
Bit rate mode                  : Variable
Maximum bit rate               : 8 373 Kbps
Channel(s)                     : 8 channels
Channel positions              : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                  : 48.0 KHz
Bit depth                      : 24 bits
Compression mode               : Lossless
Title                          : 7.1
Language                       : English
Default                        : No
Forced                         : No
DURATION                       : 01:33:37.100000000
Audio #2
Format                         : AC-3
Format/Info                    : Audio Coding 3
Mode extension                 : CM (complete main)
Format settings, Endianness    : Big
Codec ID                       : A_AC3
Duration                       : 1h 33mn
Bit rate mode                  : Constant
Bit rate                       : 640 Kbps
Channel(s)                     : 6 channels
Channel positions              : Front: L C R, Side: L R, LFE
Compression mode               : Lossy
Stream size                    : 429 MiB (5%)
Title                          : 3/2+1
Language                       : English
Default                        : Yes
Forced                         : No
DURATION                       : 01:33:37.248000000
Audio #3
Format                         : AC-3
Codec ID                       : A_AC3
Duration                       : 1h 33mn
Bit rate                       : 640 Kbps
Title                          : 3/2+1
Language                       : Swedish
Default                        : No
Forced                         : No
Audio #4
Format                         : AC-3
Codec ID                       : A_AC3
Duration                       : 1h 33mn
Bit rate                       : 640 Kbps
Title                          : 3/2+1
Language                       : Norwegian
Default                        : No
Forced                         : No
Audio #5
Format                         : AC-3
Codec ID                       : A_AC3
Duration                       : 1h 33mn
Bit rate                       : 640 Kbps
Title                          : 3/2+1
Language                       : Danish
Default                        : No
Forced                         : No
Audio #6
Format                         : AC-3
Codec ID                       : A_AC3
Duration                       : 1h 33mn
Bit rate                       : 640 Kbps
Title                          : 3/2+1
Language                       : Finnish
Default                        : No
Forced                         : No
Text #1
Format                         : PGS
Codec ID                       : S_HDMV/PGS
Codec ID/Info                  : Picture based subtitle format used on BDs/HD-DVDs
Title                          : SDH
Language                       : English
Default                        : No
Forced                         : No
DURATION                       : 01:33:07.499000000
Text #2
Format                         : PGS
Language                       : Swedish
Default                        : No
Forced                         : No
DURATION                       : 01:33:07.832000000
Text #3
Format                         : PGS
Default                        : No
Forced                         : No
Text #4
Format                         : PGS
Language                       : Danish
Default                        : No
Forced                         : No
Text #5
Format                         : PGS
Language                       : Finnish
Default                        : No
Forced                         : No
Menu
00:00:00.000                   : :Chapter 00
00:04:22.761                   : :Chapter 01
00:09:17.347                   : :Chapter 02
00:12:53.271                   : :Chapter 03
00:14:00.172                   : :Chapter 04
00:16:10.385                   : :Chapter 05
00:17:36.596                   : :Chapter 06
00:22:55.707                   : :Chapter 07
00:27:22.807                   : :Chapter 08
00:28:51.145                   : :Chapter 09
00:30:54.768                   : :Chapter 10
00:34:00.287                   : :Chapter 11
00:36:03.410                   : :Chapter 12
00:39:06.843                   : :Chapter 13
00:41:55.011                   : :Chapter 14
00:43:27.896                   : :Chapter 15
00:47:05.655                   : :Chapter 16
00:48:22.273                   : :Chapter 17
00:51:03.976                   : :Chapter 18
00:52:33.774                   : :Chapter 19
00:54:01.070                   : :Chapter 20
00:54:45.615                   : :Chapter 21
00:57:30.780                   : :Chapter 22
00:59:00.077                   : :Chapter 23
01:02:48.097                   : :Chapter 24
01:03:27.302                   : :Chapter 25
01:09:57.651                   : :Chapter 26
01:10:37.190                   : :Chapter 27
01:12:35.642                   : :Chapter 28
01:13:39.414                   : :Chapter 29
01:15:35.405                   : :Chapter 30
01:16:58.988                   : :Chapter 31
01:17:37.026                   : :Chapter 32
01:19:48.116                   : :Chapter 33
01:23:16.699                   : :Chapter 34
01:24:38.572                   : :Chapter 35
01:32:52.482                   : :Chapter 36
When I play this file, all audio tracks are shifted by one in the list. Like the name of the streams are listed starting with the TrueHD one, but the actual value mapped to the name starts at the default track.
Also, the Windows 10 app is able to play TrueHD just fine. If I default to an AC-3 track to make it direct play, and then select the TrueHD track from the list, it plays fine. But if I default to the TrueHD track, it opts to transcoding.
