Resume not working
@@rhodges
Oh oops, typo on my part. sorry guys. I will correct this asap. This error should only happen if you let kodi stop the file. If you manually stop the files does resume work correctly? Let me know.
The error was happening even if I stopped it manually.
That fixed it. I saw your changes and I edited my player.py file with the same changes.
  • Like 1
Angelblue05
So now it's resuming correctly? Thanks for confirming so quickly!
So far, so good. Thanks for the quick fix!
  • Like 1
Angelblue05
The resume fix is currently in beta version 2.2.3. @@tjlmbklr If you can give it a try and confirm that it's resolved for you too, that'd be great. Otherwise, start a new thread and post your Kodi log if you are still unable to resume correctly. Thanks.
Guest
