canada3 0 Posted February 16, 2016 Posted February 16, 2016 I am able to connect to my server via https://publicIP:8920 and http://publicIP:8096 and do things just fine. However, I have shared my server with a friend and he is trying to connect via Emby connect and it says connection failure. Do I need to forward another port for that?
Luke 42186 Posted February 16, 2016 Posted February 16, 2016 Hi, please describe what they are doing and what exactly the error says. Thanks.
canada3 0 Posted February 16, 2016 Author Posted February 16, 2016 OK. I cannot connect to my own server with the iOS app on a disparate network. I can connect to it if I go to Emby.media and login that way, and it works My friend tried to login through the emby.media site and he gets the following error (https://app.box.com/s/2lmyr1f44qf89yloaqgi0ztn9rhibrcy) Thanks for your time and effort!
Tur0k 148 Posted February 16, 2016 Posted February 16, 2016 (edited) OK. I cannot connect to my own server with the iOS app on a disparate network. I can connect to it if I go to Emby.media and login that way, and it works My friend tried to login through the emby.media site and he gets the following error (https://app.box.com/s/2lmyr1f44qf89yloaqgi0ztn9rhibrcy) Thanks for your time and effort! I am a pretty new user to emby too, but I am pretty handy with networking and server configuration. I had trouble with the IOS app when I first got my Emby Server accessible from outside my local home network. I performed the following: 1. on my home router, setup a DHCP IP address reservation for the computer that I have Emby server hosted on. this ensures that within my network that computer will always get the same IP address 2. on my home router, setup a port forward rule for TCP connections on ports 8096 and 8920 to automatically be forwarded to the IP address I reserved for the emby server computer above. 3. on the computer that has ember server installed on it, setup a firewall rule to allow TCP connections on ports 8096 and 8920 from any sources IP address to pass through the computer's firewall. the crux of my problem was two parts: a. I had hoped to only configured SSL encrypted TCP connections on port 8920 to pass through my Home router. when doing this, I found that the Emby Connect service, IOS app, and Emby Theatre app would not connect to my emby server, even though I could navigate to https://<mydomain.com>:8920. to resolve this: I ended up having to unblock and port forward unencrypted TCP connections on port 8096 to the DHCP reserved IP address that I configured for the computer that I have emby server installed on. b. the second part of my problem was related to configuring my IOS app to connect to my emby server. I found that I had to configure the server and port values as either: Server: https://<mydomain.com> Port: 8920 or Server: http://<mydomain.com> Port: 8096 Let me know if you have questions about this. Edited February 16, 2016 by Tur0k
