jhoff80 94 Posted June 2, 2016 Posted June 2, 2016 From the second post in this thread: It will be supported once it hits RC. See this post if you want to chase it yourself: http://emby.media/co...it/#entry291447
mguebert 10 Posted June 3, 2016 Posted June 3, 2016 Yeah I have it working by editing the files referenced n this thread.
e123enitan 276 Posted June 3, 2016 Posted June 3, 2016 (edited) Yeah I have it working by editing the files referenced n this thread. Nice, when I change the file kodi respond not supported, could u share your addon, I can't seem to get it to work. Does anyone know where the file to change is located, I could be using incorrect file, pls post a link . Thanks Edited June 3, 2016 by e123enitan
mguebert 10 Posted June 3, 2016 Posted June 3, 2016 See these threads http://emby.media/community/index.php?/topic/30324-yall-are-killing-it/&do=findComment&comment=291447 https://github.com/MediaBrowser/plugin.video.emby/commit/d95d854f70b19bc698c9f17f392de0bffe6e1a18 and see this comment "There may be more than one place you'll have to fix this in utils.py so it's plugin.video.emby instead of plugin.video.metaman"
spootdev 56 Posted June 4, 2016 Posted June 4, 2016 and see this comment "There may be more than one place you'll have to fix this in utils.py so it's plugin.video.emby instead of plugin.video.metaman" That boo-boo should have been fixed quite some time ago. Did I miss another one?
mguebert 10 Posted June 6, 2016 Posted June 6, 2016 Not sure I haven't messed with it since I got it working, but on the Krypton build I am using those edits were needed.
e123enitan 276 Posted June 6, 2016 Posted June 6, 2016 (edited) Not sure I haven't messed with it since I got it working, but on the Krypton build I am using those edits were needed. Thanks for your response, correct if I'm wrong it appears that Krypton code, have been added by im85288 thanks to that https://github.com/MediaBrowser/plugin.video.emby/commit/d95d854f70b19bc698c9f17f392de0bffe6e1a18, or this is just as a guide for those that wishes to chase Krypton. so I did a download of the add-on (plugin.video.emby-master) from here https://github.com/MediaBrowser/plugin.video.emby. When i load it, it says, dependency is missing, not sure if I am doing the right thing Anyway, I am not too crazy to have Krypton now just curious to see how it would fair out, I appreciate the developer have set RC to when to begin supporting Krypton, that said, I would welcome/appreciate anyone pointing me to the plugin zip file, if it doesn't work fine, not the end of the world Cheers! Edited June 6, 2016 by e123enitan
xnappo 1611 Posted June 7, 2016 Posted June 7, 2016 @@e123enitan, Fromt that error I don't think a zip will help. Can you play a log?
e123enitan 276 Posted June 7, 2016 Posted June 7, 2016 @@e123enitan, Fromt that error I don't think a zip will help. Can you play a log? U mean I should post log, most appreciated, I should mention that when I download the zip in this link https://github.com/MediaBrowser/plugin.video.emby I hope is the right one, as I noted krypton changes are been added, I loaded the file into Krypton and Javis it respond with dependence missing. I may be wrong in my appraoch, I appreciate if you have time to guide me or assist with this issue, as I don't want to bug you guys, you have been awesome in your past supports and Emby/kodi build, anyway, I shall post log for your review. Cheers!
Angelblue05 4132 Posted June 7, 2016 Posted June 7, 2016 Do you have our repository installed? You will need to have it installed so once you manually install the zip, it grabs the dependencies from our repository. Sent from my iPhone using Tapatalk 1
e123enitan 276 Posted June 10, 2016 Posted June 10, 2016 (edited) Do you have our repository installed? You will need to have it installed so once you manually install the zip, it grabs the dependencies from our repository. Sent from my iPhone using Tapatalk Yes but what I think may have caused the issue, the lastest Krypton MyVideoDB105, compare to what is currently in Plugin.video.emby-master , as noted other thread this would continue to change until the RC, I dont expect supports as I am firm believer of your policy not to support at Alpher state. I went to convert those file affected to txt, make my changes, but my challenge is how to change he files back to py, any idea, I will do this my self if I have the tools, hope its not a rocket science, I'm guessing its like zip sort of, I may be wrong Cheers! Edited June 10, 2016 by e123enitan 1
Angelblue05 4132 Posted June 10, 2016 Posted June 10, 2016 (edited) You don't have to convert to txt. Simply right click the .py file > Edit in Notepad. Edited June 10, 2016 by Angelblue05
