roberthleeii 62 Posted February 16, 2016 Posted February 16, 2016 (edited) I noticed that emby mislabeled the move Max as Mad Max: Fury Road, a movie already on the sever so I went in to identify it and update the images but I had a problems and would not work right so I moved the movie and deleted all the files in the folder except for the MP4 video. I noticed that it was hanging when I scanned the library (so the service could identify that I had removed the movie). I decided to update the server to the newest stable release and then restarted my whole computer making sure that nothing else was causing problems. I was able to get the server to complete a scan with no changes so I tried to put the movie back and scan for the changes. It froze at 39.1% just after making the Roku thumbnails. It still identifies it as mad max but with no images and most of the metadata missing. I can’t even successfully edit and identify the movie. The little spinning circle just spins and spins. Please help I have included a log from the last time I restarted the program and added the movie. Please help. Robert Log.txt Edited February 16, 2016 by roberthleeii
roberthleeii 62 Posted February 16, 2016 Author Posted February 16, 2016 Well i restarted the server and it all seemed to work, now. I would still like for someone to look over the log file to see what is happening. I would like to make sure i don't have any problems. I have included a log file from restart to updating the metadata, and preforming a new scan. Please let me know if there is a problem I need to address or at least what was happening before. Log.txt
Luke 42186 Posted February 16, 2016 Posted February 16, 2016 what you are perceiving as frozen could just be the system under heavy load due to the thumbnail generation. i would disable the roku plugin, then try to use the identify feature.
