Overseer 66 Posted February 15, 2016 Posted February 15, 2016 Good Day, Could external player setup in EMC configuration be based also on tags and not just file-type? I currently have my 3D MVC movies named with the .mk3d extension and external player set to use MPC-BE to play those files (which works great) but have a tendency sometimes to forget to rename the extension from .mkv to .mk3d. With external playback based on tags I won't need to do that anymore and can just merge my 3D movies into my main movie collection instead of separating them out. Possible to implement? Thanks.
ebr 16332 Posted February 15, 2016 Posted February 15, 2016 It is already possible to define different external players for standard vs. 3D format items.
Overseer 66 Posted February 15, 2016 Author Posted February 15, 2016 (edited) Ok, so I went to test this out. I renamed one of my 3D MVC movies from .mk3d to .mkv and set configurator to use MPC-BE as external player for .mkv supported media type and Digital3D for supported video format to test this out. I went into EMC to test this out but ran into an issue with EMC recognizing MVC as a 3D format. Type=Newtonsoft.Json.JsonSerializationException Msg=Error converting value "MVC" to type 'System.Nullable`1[MediaBrowser.Model.Entities.Video3DFormat]'. Path 'Items[58].Video3DFormat',, line 1,, position 234441. I currently have my 3D movies in a separate directory and a separate folder for Emby. I played around with the web metadata manager to identify some of my 3D movies using the new 3D type info. When I try to go into my 3D folder in EMC I get he following error. The emby program has stopped responding and you will be returned to Windows Media Center. This is the same for Classis, Chocolate and Square themes and only happens when I go to the 3D folder. All other folders work fine. Log attached. MBClassic-15220165fa4cf74c3c2435986ab055bddc1e9c1.log Edit: I should mention that this is with EMC version .298. Edited February 15, 2016 by Overseer
ebr 16332 Posted February 15, 2016 Posted February 15, 2016 Yeah, that's going to be an issue due to the change that Luke just made to the server...
ebr 16332 Posted February 15, 2016 Posted February 15, 2016 Please try the new release of EMC I just put up.
Overseer 66 Posted February 15, 2016 Author Posted February 15, 2016 Ok, downloaded and installed .299, but still have the same issue. All folders are accessible except the 3D folder. That is with both Classic and Chocolate themes. MVC error at around 13:54:35 and 13:55:29 mark. MBClassic-15220167037eebbbdfa45bca3ebee0ba274f059.log
ebr 16332 Posted February 15, 2016 Posted February 15, 2016 Okay, apparently the component isn't updated yet. I can hopefully get it out tomorrow am.
Solution ebr 16332 Posted February 16, 2016 Solution Posted February 16, 2016 Okay, please try .300. It is a dev version so you will need to change your update level (just in EMC) to see it. 1
Overseer 66 Posted February 16, 2016 Author Posted February 16, 2016 Ok, I'm at work at the moment. i'll hit it up when I get home. Thank you.
Overseer 66 Posted February 17, 2016 Author Posted February 17, 2016 (edited) Ok, EMC no longer crashes with movies tagged as MVC for 3D format using the .300 version. Thank you. This brings me back to the original topic at hand which is having EMC open movies tagged as MVC in an external player. I have a 3D movie file that is created using MakeMKV. It is a 1-for-1 copy. It is saved with the .mkv file extension. I go into Emby web interface to edit the metadata to reflect 3D format as MVC. I go into EMC configurator and select file type as mkv and file format as either Digital3D or SBS-3D it will not play using the external player. If I rename the file with the .mk3d extension and tell configurator to play mk3d files externally it works. MVC files with the mkv extension are not recognized by EMC to play externally. EMC does recognize my SBS encoded files for external playback. Thanks. Edited February 17, 2016 by Overseer
ebr 16332 Posted February 17, 2016 Posted February 17, 2016 It should be obeying the configuration for "Digital 3D"...
Overseer 66 Posted February 17, 2016 Author Posted February 17, 2016 It should be obeying the configuration for "Digital 3D"... Unfortunately, it does not. I have the file named as: "Movie (YEAR) 3D MVC.mkv" as reflected in the wiki. I have MVC set in the metadata 3D FORMAT field. I have CONFIGURATOR set to play MKV - DIGITAL3D using external (MPC-BE) player but EMC plays it with the internal player. The video plays as it should in 3D if played directly with MPC-BE so I know it's not an issue with the file itself. Here's the Mediainfo data on one of my MVC files if this will help. General Unique ID : 155111951433290487604832492349646836194 (0x74B179A6B134B45DD352E419973E11E2) Complete name : E:\ServerFolders\Videos\3D-Movies\XXXXXXX (2015)\XXXXXXX (2015) 3D MVC.mkv Format : Matroska Format version : Version 2 File size : 34.4 GiB Duration : 1h 57mn Overall bit rate mode : Variable Overall bit rate : 42.0 Mbps Movie name : XXXXXXXXXXXXXXX - BLU-RAY 3D Encoded date : UTC 2016-01-25 05:32:41 Writing application : MakeMKV v1.9.8 win(x64-release) Writing library : libmakemkv v1.9.8 (1.3.3/1.4.4) win(x64-release) Original source medium : Blu-ray Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : Stereo High@L4.1 / High@L4.1 MultiView_Count : 2 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Format settings, GOP : M=1, N=12 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 57mn Bit rate mode : Variable Bit rate : 3 580 Kbps Maximum bit rate : 33.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.072 Stream size : 29.3 GiB (85%) Language : English Default : No Forced : No Audio #1 ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 57mn Bit rate mode : Variable / Constant Bit rate : 468 Kbps / 1 509 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 3.83 GiB (11%) Title : Surround 7.1 Language : English Default : Yes Forced : No Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 57mn Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.23 GiB (4%) Title : Surround 5.1 Language : English Default : No Forced : No Text ID : 4 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1h 56mn Bit rate : 4 025 bps Count of elements : 3432 Stream size : 33.6 MiB (0%) Language : English Default : No Forced : No Menu 00:00:00.000 : en:Chapter 01 00:02:08.837 : en:Chapter 02 00:08:40.186 : en:Chapter 03 00:15:24.840 : en:Chapter 04 00:19:59.740 : en:Chapter 05 00:27:50.210 : en:Chapter 06 00:33:07.235 : en:Chapter 07 00:38:53.956 : en:Chapter 08 00:44:36.465 : en:Chapter 09 00:49:22.459 : en:Chapter 10 00:57:44.252 : en:Chapter 11 01:00:48.811 : en:Chapter 12 01:06:31.529 : en:Chapter 13 01:23:21.287 : en:Chapter 14 01:34:20.529 : en:Chapter 15 01:47:34.072 : en:Chapter 16 Thanks.
ebr 16332 Posted February 17, 2016 Posted February 17, 2016 Please post the EMC log from when you try to play it. Thx.
Overseer 66 Posted February 17, 2016 Author Posted February 17, 2016 Sorry about the delay, just got off work. Ok, not sure what has changed between yesterday and today, but 3D MVC is now playing correctly using external player. It really is the strangest thing and I can't figure out what has changed. Anywho, it's working correctly now. Consider this issue closed. Thanks.
