tekfranz 6 Posted May 14, 2019 Posted May 14, 2019 (edited) Have a look at mailgun rather than gmail. they provide 10000 free email sends per month - however you do need your own domain nameThanks that worked after a journey through Linux sendmail. Emails are sending now but all I get is stop notifications from fail2ban, no BAN emails from EMBY even though I get Ban entries from the EMBY filter in the fail2ban logs. I have the same issue described here: https://github.com/fail2ban/fail2ban/issues/2146 Edited May 14, 2019 by tekfranz
Andrew0991 0 Posted July 23, 2019 Posted July 23, 2019 Hi, I think this is correct place to put this info, helpfull when emby is behind reverseproxy. According to closed ticket: https://github.com/MediaBrowser/Emby/issues/1223 Logs can be send to remote syslog, using imfile feature in rsyslog. https://www.rsyslog.com/doc/v8-stable/configuration/modules/imfile.html#state-files Below is my configuration for rsyslog on emby server: Path: /etc/rsyslog.d/00-emby.conf $WorkDirectory /var/spool/rsyslog $ModLoad imfile $ModLoad imtcp $InputFileName /var/lib/emby/logs/embyserver.txt $InputFileTag emby: $InputRunFileMonitor # send only important for fail2ban logs. if $msg contains 'Warn' or $msg contains 'Info' or $msg contains 'Error' then @@REMOTE_SYSLOG_IP & stop
