MSattler 390 Posted February 14, 2016 Posted February 14, 2016 I know the Live TV is still experimental, however it works great for me with one exception: When I stop playback of LiveTV, it does not kill the ffmpeg process that is created to transcode the playback. If I stop and start multiple times, those ffmpeg processes keep running. thanks!
Angelblue05 4132 Posted February 14, 2016 Posted February 14, 2016 (edited) Hmmm. If it's transcoding, it should automatically delete the process after playback stops. Do you mind posting your Kodi log so I can see why it's not working? I do not have Live TV, thanks Edit: Never mind, I think I found the issue. For some reason it was being marked as Direct Play, but it's really transcoding. The fix is in beta 2.1.3 Edited February 14, 2016 by Angelblue05
SkyBehind 23 Posted February 14, 2016 Posted February 14, 2016 I know the Live TV is still experimental, however it works great for me with one exception: When I stop playback of LiveTV, it does not kill the ffmpeg process that is created to transcode the playback. If I stop and start multiple times, those ffmpeg processes keep running. thanks! Same
Angelblue05 4132 Posted February 14, 2016 Posted February 14, 2016 See my post above @@SkyBehind Sent from my iPhone using Tapatalk
MSattler 390 Posted February 14, 2016 Author Posted February 14, 2016 See my post above @@SkyBehind Sent from my iPhone using Tapatalk
MSattler 390 Posted February 14, 2016 Author Posted February 14, 2016 Hmm still not working with 2.1.3. http://xbmclogs.com/pt4limxmx Thanks! PS. Sometimes, say I stop playback, reboot, play that channel again no ffmpeg process is picked up and it plays previously recorded live tv. Is it possible that the transcoding cache is not being cleared fast enough and so it plays that back? 1
Angelblue05 4132 Posted February 15, 2016 Posted February 15, 2016 Weird, because according to your log, the transcode was ended correctly. Do you have the server log from that time?
MSattler 390 Posted February 15, 2016 Author Posted February 15, 2016 Weird, because according to your log, the transcode was ended correctly. Do you have the server log from that time? Very weird, but the server log shows this: FFMpeg exited with code -1 Perhaps it has something to do with that? Below is a snippet of the log, if it's not enough I can go ahead and restart the server later and run another test. Thanks! 2016-02-14 22:37:44.4064 Info HttpServer: HTTP Response 500 to 73.12.70.235. Time: 1187ms (slow). https://emby.marcusrocks.com:8920/videos/fbd1db53b51e19b040512e200c4f38c2/hls1/main/480.ts?DeviceId=914056ee4d74e400f758d239390f731245267fe9&MediaSourceId=fbd1db53b51e19b040512e200c4f38c2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3680000&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1164bcfdb5a64f8b866b01308e2e04e8&api_key=cc1cb7d2c96a46daa3ae3b0a5e074f4a 2016-02-14 22:37:45.5920 Info HttpServer: HTTP GET https://emby.marcusrocks.com:8920/videos/fbd1db53b51e19b040512e200c4f38c2/hls1/main/481.ts?DeviceId=914056ee4d74e400f758d239390f731245267fe9&MediaSourceId=fbd1db53b51e19b040512e200c4f38c2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3680000&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1164bcfdb5a64f8b866b01308e2e04e8&api_key=cc1cb7d2c96a46daa3ae3b0a5e074f4a. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_5) AppleWebKit/601.4.4 (KHTML, like Gecko) Version/9.0.3 Safari/601.4.4 2016-02-14 22:37:46.4978 Info HttpServer: HTTP Response 200 to 73.12.70.235. Time: 906ms. https://emby.marcusrocks.com:8920/videos/fbd1db53b51e19b040512e200c4f38c2/hls1/main/481.ts?DeviceId=914056ee4d74e400f758d239390f731245267fe9&MediaSourceId=fbd1db53b51e19b040512e200c4f38c2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3680000&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1164bcfdb5a64f8b866b01308e2e04e8&api_key=cc1cb7d2c96a46daa3ae3b0a5e074f4a 2016-02-14 22:37:46.8566 Info HttpServer: HTTP GET https://emby.marcusrocks.com:8920/videos/fbd1db53b51e19b040512e200c4f38c2/hls1/main/482.ts?DeviceId=914056ee4d74e400f758d239390f731245267fe9&MediaSourceId=fbd1db53b51e19b040512e200c4f38c2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3680000&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1164bcfdb5a64f8b866b01308e2e04e8&api_key=cc1cb7d2c96a46daa3ae3b0a5e074f4a. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_5) AppleWebKit/601.4.4 (KHTML, like Gecko) Version/9.0.3 Safari/601.4.4 2016-02-14 22:37:47.3090 Info HttpServer: HTTP Response 200 to 73.12.70.235. Time: 452ms. https://emby.marcusrocks.com:8920/videos/fbd1db53b51e19b040512e200c4f38c2/hls1/main/482.ts?DeviceId=914056ee4d74e400f758d239390f731245267fe9&MediaSourceId=fbd1db53b51e19b040512e200c4f38c2&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3680000&AudioBitrate=320000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=1164bcfdb5a64f8b866b01308e2e04e8&api_key=cc1cb7d2c96a46daa3ae3b0a5e074f4a 2016-02-14 22:37:49.3692 Info HttpServer: HTTP GET http://192.168.1.125:8096/dlna/69251f6cc4ad96a5320ed9c78345f822/description.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Kodi 2016-02-14 22:37:49.3692 Info HttpServer: HTTP Response 200 to 192.168.1.57. Time: 0ms. http://192.168.1.125:8096/dlna/69251f6cc4ad96a5320ed9c78345f822/description.xml 2016-02-14 22:37:50.3686 Info HttpServer: HTTP GET http://192.168.1.125:8096/dlna/69251f6cc4ad96a5320ed9c78345f822/description.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Kodi 2016-02-14 22:37:50.3842 Info HttpServer: HTTP Response 200 to 192.168.1.64. Time: 16ms. http://192.168.1.125:8096/dlna/69251f6cc4ad96a5320ed9c78345f822/description.xml 2016-02-14 22:37:53.6778 Info App: FFMpeg exited with code -1
Angelblue05 4132 Posted February 15, 2016 Posted February 15, 2016 @@marcelveldt You want to look into this?
e123enitan 276 Posted February 15, 2016 Posted February 15, 2016 @@marcelveldt You want to look into this? @ Angelblue & Teams Just want to appreciate version 2.1.3, thanks to you guys, One qustion though, the Live TV as mention in this thread, what is the source, is it from emby server? or could you elaborate how to incorporate this. Thanks
e123enitan 276 Posted February 15, 2016 Posted February 15, 2016 @ Angelblue & Teams Just want to appreciate version 2.1.3, thanks to you guys, One qustion though, the Live TV as mention in this thread, what is the source, is it from emby server? or could you elaborate how to incorporate this. Thanks I got it is from emby server, I believe this the one marcel is experimenting with, so will work regardless of the plugin one use in the server?
Angelblue05 4132 Posted February 15, 2016 Posted February 15, 2016 I do not have live tv so this is difficult for me to help with. I don't have any idea how it works. It is marcel's experimental feature, so hopefully he can jump in on this conversation to help out. Sent from my iPhone using Tapatalk
