BinaryShrub 3 Posted February 13, 2016 Posted February 13, 2016 (edited) I have changed system.xml and set <DenyIFrameEmbedding>false</DenyIFrameEmbedding> but I am still seeing the error refused to display in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'. Can anyone verify if this is working for them or not? Was there a code change recently that might of affected this? Version 3.0.5821.0 | Ubuntu 14.0.4.3 Logs: https://drive.google.com/file/d/0Bzjt-xqPcZoYdG56eU1tSWtGdTg/view?usp=sharing Edited February 13, 2016 by BinaryShrub
BinaryShrub 3 Posted February 13, 2016 Author Posted February 13, 2016 Looking through the code it doesnt look like any of it was touched recently... not sure what else I can try.
Luke 42243 Posted February 13, 2016 Posted February 13, 2016 hi, welcome. see if the header is still being added. if it is, then the config value wasn't set correctly.
BinaryShrub 3 Posted February 14, 2016 Author Posted February 14, 2016 I havent made any progress, I am going to try reinstalling and see if that works
Solution BinaryShrub 3 Posted February 14, 2016 Author Solution Posted February 14, 2016 Reinstall fixed the issue, maybe I screwed something up in the xml file while messing around with it. 1
