EduardoSantos 40 Posted February 13, 2016 Posted February 13, 2016 Emby will not start. This is a Windows 10 x64 instal. Previous version was running Ok - unfortunely I do not know the version number. Attached are install and server logs. Any help would be of great use. server-63590902400.txt server-install.log
EduardoSantos 40 Posted February 13, 2016 Author Posted February 13, 2016 (edited) Sorry. It is really the whole log. I have uninstalled it and installed again but the result is the same. When started, Emby even briefely shows the splash screen but the process aborts. I can generate other log files restarting or reinstalling it but they surely will look the same (already did it). Any idea? Edited February 13, 2016 by EduardoSantos
Happy2Play 9800 Posted February 13, 2016 Posted February 13, 2016 You didn't change from dev or beta back to stable/official release did you?
EduardoSantos 40 Posted February 13, 2016 Author Posted February 13, 2016 That can be. As I told, the previous version that was working ok was installed from a file downloaded from emby.media/download but there was no stable/beta options. I got the impression that this previous was a beta release. Anyway, I got Emby uninstalled and deleted all AppData\Roaming\Emby-Server folders. I even created another Windows user and tried to install using it.
Happy2Play 9800 Posted February 13, 2016 Posted February 13, 2016 (edited) The version listed in the log show 3.0.5821.0 which is the stable/official release. If you were on dev or beta before then downgrading is/was not an option do to the database changes. That may have been your issue. Edit tested downgrading and Emby still launched so that couldn't have been your issue. Yes emby.media/download has Stable and Beta options. Edited February 13, 2016 by Happy2Play
EduardoSantos 40 Posted February 13, 2016 Author Posted February 13, 2016 Ok, so my problem is not due to version upgrade. But I still have no idea on how to tackle this, so please help.
Luke 42186 Posted February 13, 2016 Posted February 13, 2016 if it happens on a clean install then consider running hardware diagnostics to search for any possible failures. chkdsk would be a good start.
QwEmby 2 Posted February 14, 2016 Posted February 14, 2016 Emby will not start. This is a Windows 10 x64 instal. Previous version was running Ok - unfortunely I do not know the version number. Attached are install and server logs. Any help would be of great use. Same here. Emby won't start at all.
Happy2Play 9800 Posted February 14, 2016 Posted February 14, 2016 Same here. Emby won't start at all. Can you post your server log.
EduardoSantos 40 Posted February 14, 2016 Author Posted February 14, 2016 Checkdisk tells volume is clean. Another suggestion, please?
EduardoSantos 40 Posted February 20, 2016 Author Posted February 20, 2016 Emby started. I used the previous restore point to restore Windows and then Emby started Ok,
