themen 1 Posted February 11, 2016 Posted February 11, 2016 (edited) Hi, when i want to play in emby a ISO file there is only the video but no sounds. My emby Version is 3.0.5869.0. I hope you can help me. Also there is no Sound Symbol in the top right. Sorry for my bad Englisch. Edited February 11, 2016 by themen
Luke 42243 Posted February 11, 2016 Posted February 11, 2016 Hi there, welcome. In order to best help you, please see how to report a media playback issue. Thanks!
themen 1 Posted February 11, 2016 Author Posted February 11, 2016 (edited) Thanks. Okay: Description: When I want to play a ISO file in emby and I klick the button "play" then the film starts normal but without sounds. At the top right I can change the qualtity of the video but there are no options for the sound. When I play the ISO file on my PC it works. There are no Error messages in the Webinterface. My RootServer using Ubuntu 14.04. server-63590817681.txt transcode-986f42ac-c59d-4ac9-ab91-1f3124d2bf02.txt Edited February 11, 2016 by themen
Solution Luke 42243 Posted February 11, 2016 Solution Posted February 11, 2016 Hi, ok, I see. You're trying to play the ISO in an app that requires transcoding. Please note, we consider this feature expiremental because ffmpeg does not fully support it. Notice how ffmpeg detects 0 audio channels: Input #0, mpeg, from 'file:/home/luka/Filme/DESPICABLE_ME_2.iso': Duration: 00:00:58.31, start: 0.336711, bitrate: 883720 kb/s Stream #0:0[0x1bf]: Data: dvd_nav_packet Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, bt470bg), 720x576 [SAR 64:45 DAR 16:9], 8000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:2[0x80]: Audio: ac3, 0 channels If you want to play ISO's then you'll need to use Emby Htpc apps such as Emby for Windows Media Center, Emby for Kodi, or Emby Theater (old version, new version doesnt' support it yet). You can read more here: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming 1
