gebhard 4 Posted February 9, 2016 Posted February 9, 2016 Hi, I've put some pictures (JPG) in a directory of a mixed library. Directory listing: The directory can be accessed by Emby, the pictures should also be accessible (other: r). But the content of the Folder "Dies-und-das" is not displayed, the folder in the library is empty: Log: log.txt Emby Version 3.0.5821.0 Thanks, Gebhard
Luke 42237 Posted February 9, 2016 Posted February 9, 2016 Hi, for photos you need to use Content Type Photos. They are not supported in any other kind of library at the moment. thanks. 1
gebhard 4 Posted February 9, 2016 Author Posted February 9, 2016 aaaahhh... this helps... thanks for the fast reply... really feeling like a n00b :-(
gebhard 4 Posted February 9, 2016 Author Posted February 9, 2016 When I try to download a picture I get an error and the following shows up in the log: 2016-02-09 20:57:07.7622 Info HttpServer: HTTP Response 200 to 192.168.1.108. Time: 12ms. http://192.168.1.165:8096/emby/Users/a34978150f9948639fa9e3b6df68b2df/Items?SortBy=SortName&SortOrder=Ascending&Fields=DateCreated%2CPrimaryImageAspectRatio%2CMediaSourceCount%2CSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CBanner%2CThumb&StartIndex=0&Limit=100&ParentId=b74fa8ab0b84283058b0e5f9613c8ec4 2016-02-09 20:57:10.3117 Info HttpServer: HTTP GET http://192.168.1.165:8096/emby/Items/9ca068ada71b8eacf259b95f785ef4bf/Download?api_key=f6bcfb9a70d74d58948eaccede0a4f1d. UserAgent: Mozilla/5.0 (Linux; Android 5.1.1; ONE A2003 Build/LMY47V; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/47.0.2526.100 Mobile Safari/537.36 2016-02-09 20:57:10.3139 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5821.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe Item does not support downloading System.ArgumentException at MediaBrowser.Api.Library.LibraryService.Get (MediaBrowser.Api.Library.GetDownload request) <0x8167ea780 + 0x0033d> in <filename unknown>:0 at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,object,object) at ServiceStack.Host.ServiceRunner`1[TRequest].Execute (IRequest request, System.Object instance, ServiceStack.Host.TRequest requestDto) <0x80ffb2a40 + 0x0045b> in <filename unknown>:0 2016-02-09 20:57:10.3139 Error HttpServer: Error processing request for /emby/Items/9ca068ada71b8eacf259b95f785ef4bf/Download?api_key=f6bcfb9a70d74d58948eaccede0a4f1d *** Error Report *** Version: 3.0.5821.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe Item does not support downloading ServiceStack.HttpError No Stack Trace Available 2016-02-09 20:57:10.3155 Info HttpServer: HTTP Response 400 to 192.168.1.108. Time: 4ms. http://192.168.1.165:8096/emby/Items/9ca068ada71b8eacf259b95f785ef4bf/Download?api_key=f6bcfb9a70d74d58948eaccede0a4f1d 2016-02-09 20:57:12.3731 Info App: Scan media library Completed after 0 minute(s) and 15 seconds 2016-02-09 20:57:20.4789 Info App: HttpClientManager GET: http://192.168.1.104:49153/nmrDescription.xml 2016-02-09 20:57:20.6947 Info App: HttpClientManager GET: http://192.168.1.104:49153/dmr/nmrRenderingControl.xml 2016-02-09 20:57:20.7051 Error App: Error getting response from http://192.168.1.104:49153/dmr/nmrRenderingControl.xml *** Error Report *** Version: 3.0.5821.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe One or more errors occurred. System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808123920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x80ff62650 + 0x01110> in <filename unknown>:0 InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x80fd50e00 + 0x0020d> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x80ffc8580 + 0x00093> in <filename unknown>:0 2016-02-09 20:57:20.7062 Error Dlna: Error creating PlayTo device. *** Error Report *** Version: 3.0.5821.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe One or more errors occurred. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x80ff62650 + 0x0197d> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808123920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () <0x80ff5d170 + 0x0022c> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808123920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>c__async0.MoveNext () <0x80ffec3f0 + 0x00188> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808123920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Dlna.PlayTo.SsdpHttpClient+<GetDataAsync>c__async2.MoveNext () <0x8168a9920 + 0x00310> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () <0x815a37d00 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Dlna.PlayTo.Device+<GetRenderingProtocolAsync>c__async11.MoveNext () <0x8168e2fb0 + 0x003a3> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () <0x80808cb00 + 0x0001a> in <filename unknown>:0 at MediaBrowser.Dlna.PlayTo.Device+<CreateuPnpDeviceAsync>c__async12.MoveNext () <0x8168a71a0 + 0x01ca5> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808123920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Dlna.PlayTo.PlayToManager+<_deviceDiscovery_DeviceDiscovered>c__async0.MoveNext () <0x80ffe04a0 + 0x00935> in <filename unknown>:0 InnerException: System.AggregateException One or more errors occurred. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x80fe288f0 + 0x00038> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x80fe28110 + 0x00118> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x80fe27830 + 0x000b3> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x80808cb30 + 0x00042> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x808123920 + 0x0001f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x80ff62650 + 0x01110> in <filename unknown>:0 InnerException: System.Net.WebException The remote server returned an error: (404) Not Found. at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x80fd50e00 + 0x0020d> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x80ffc8580 + 0x00093> in <filename unknown>:0 2016-02-09 20:57:28.2233 Info HttpServer: HTTP GET http://192.168.1.165:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Linux; Android 5.1.1; ONE A2003 Build/LMY47V; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/47.0.2526.100 Mobile Safari/537.36 2016-02-09 20:57:28.2252 Info HttpServer: HTTP Response 200 to 192.168.1.108. Time: 2ms. http://192.168.1.165:8096/emby/system/info/public 2016-02-09 20:57:28.2733 Info HttpServer: HTTP GET http://192.168.1.165:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Linux; Android 5.1.1; ONE A2003 Build/LMY47V; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/47.0.2526.100 Mobile Safari/537.36 Thanks, Gebhard
Luke 42237 Posted February 9, 2016 Posted February 9, 2016 I don't know. please always attach complete log files. thanks.
Luke 42237 Posted February 10, 2016 Posted February 10, 2016 Thanks. can you please discuss what you tried to do prior to that screen? thanks.
gebhard 4 Posted February 10, 2016 Author Posted February 10, 2016 Hi, I've tried to download one of the pictures I mentioned earlier in this post. Cheers
