GlennNZ 92 Posted November 5, 2020 Author Posted November 5, 2020 7 hours ago, Red5ive said: Glad you are well Glenn! Any thoughts on my post above with possibly using Darksky as an alternative to get the weather working again? My screen is stuck on the raining image for the past 6 months (which is usually correct seeing as I'm in the UK but still be nice to have it working again!) Thanks. I’ll see what I can have a look at, but no promises...
GlennNZ 92 Posted November 7, 2020 Author Posted November 7, 2020 (edited) On 06/11/2020 at 00:01, Red5ive said: Glad you are well Glenn! Any thoughts on my post above with possibly using Darksky as an alternative to get the weather working again? My screen is stuck on the raining image for the past 6 months (which is usually correct seeing as I'm in the UK but still be nice to have it working again!) New Version: 1.315 Change Weather to OpenWeatherOrg from DarkSky (as closing following Apples purchase) Needs free API key from OpenWeatherOrg - entered into Weather Settings Page. Re-Merge earlier Emby Remote changes; not carried through to most recent version it would seem Check Plex connection/Server: Functions correctly; always chooses local client (running on same computer as FrontView) Reminder: To setup Plex: select Plex server IP/Port (usually 32400) and username, password for Server. FV will then display info on the same computer it is running (eg. always local to FV client selected) As above - hopefully sorts out weather for you moving forward! https://github.com/Ghawken/FrontView/releases/ Thanks Glenn Edited November 7, 2020 by GlennNZ
Red5ive 30 Posted November 10, 2020 Posted November 10, 2020 Just tried the new version and happy to report that the weather is now working correctly again. Had to look up and change the coordinates for my location from the OpenWeatherOrg site and there was a while before the updated weather came through but all good now If only I could move the weather info box to the left a bit (and other screen elements) so it is not covered by the date and time - I have to have the font size up so big so I can see it on my 5" case screen, but that's an ongoing issue Thanks for your continued support Glenn
GlennNZ 92 Posted November 11, 2020 Author Posted November 11, 2020 (edited) 20 hours ago, Red5ive said: Just tried the new version and happy to report that the weather is now working correctly again. Had to look up and change the coordinates for my location from the OpenWeatherOrg site and there was a while before the updated weather came through but all good now If only I could move the weather info box to the left a bit (and other screen elements) so it is not covered by the date and time - I have to have the font size up so big so I can see it on my 5" case screen, but that's an ongoing issue Thanks for your continued support Glenn Glad to hear - yes restart or wait bit for update. Like darksky need longititude/latitude. Coming back to size/position: You may find for your tiny screen (I replaced mine with a standalone cheap 10” led touch screen with box now hidden) that the overall size slider is what you need to change. Often change font/aspects down (which is counter productive) and then change the whole screen size slider up or down... (the ALL size one) With this combo of factors can achieve any scale format with a bit of trial and error Other aspect is sometimes tiny screen will accept a bigger resolution than it has pixels (eg.640x480, but will display scale 800x600) some changes in layout as screen size goes above 640 which may be helpful. Failing both these always a 2nd screen connected via HDMI/DP.... Can’t find the one I got ages ago, but like.. (this isnt touch screen admittedly...)https://www.aliexpress.com/item/4001010476484.html Glenn Edited November 11, 2020 by GlennNZ
jachin99 88 Posted October 25, 2021 Posted October 25, 2021 @Luke @GlennNZ I tried downloading the emby plugin from the catalog but it looks like nothing downloads. I get a folder icon on my installed plugins screen instead of the frontview logo, and I can't find an actual assembly in my programdata/plugin folders. I also can't find any frontview configuration files anywhere in emby's folder structure. Thanks.
Luke 42239 Posted October 25, 2021 Posted October 25, 2021 Just now, jachin99 said: @Luke @GlennNZ I tried downloading the emby plugin from the catalog but it looks like nothing downloads. I get a folder icon on my installed plugins screen instead of the frontview logo, and I can't find an actual assembly in my programdata/plugin folders. I also can't find any frontview configuration files anywhere in emby's folder structure. Thanks. Server log?
jachin99 88 Posted October 25, 2021 Posted October 25, 2021 Forgot to mention Iḿ on a beta server. Iḿ attaching logs from before and after I reset the server to complete the plugin install embyserver-63770762714.txt embyserver.txt
Luke 42239 Posted October 26, 2021 Posted October 26, 2021 8 hours ago, jachin99 said: Forgot to mention Iḿ on a beta server. Iḿ attaching logs from before and after I reset the server to complete the plugin install embyserver-63770762714.txt 4.73 MB · 0 downloads embyserver.txt 166.99 kB · 0 downloads Can you install other plugins?
jachin99 88 Posted October 26, 2021 Posted October 26, 2021 I just tried installing the IPTV plugin with no success but I do at least get the IPTV icon on my plugin screen vs a generic logo for frontview. Here are the logs embyserver-63770834976.txt embyserver.txt
Luke 42239 Posted October 26, 2021 Posted October 26, 2021 1 hour ago, jachin99 said: I just tried installing the IPTV plugin with no success but I do at least get the IPTV icon on my plugin screen vs a generic logo for frontview. Here are the logs embyserver-63770834976.txt 4.35 MB · 0 downloads embyserver.txt 2.61 MB · 0 downloads Which one is from when you tried to install iptv? What time did you do that?
jachin99 88 Posted October 26, 2021 Posted October 26, 2021 The log where I installed IPTV should be the one ending in .976. Afterwards I restarted emby It created a new log, and that is the embyserver.txt.
Luke 42239 Posted October 26, 2021 Posted October 26, 2021 2 hours ago, jachin99 said: The log where I installed IPTV should be the one ending in .976. Afterwards I restarted emby It created a new log, and that is the embyserver.txt. Are you behind a VPN? It looks like something is interfering with the plugin downloads.
jachin99 88 Posted October 26, 2021 Posted October 26, 2021 No VPN or anything. The only potential issue MIGHT be that I was recording via playon at the time. I don´t think that would do anything though
jachin99 88 Posted October 26, 2021 Posted October 26, 2021 I disabled playon, and i still get the same result. I'm looking for new plugins to show up in programdata/plugins. Is that right? Are there any network settings I need to look at in emby?
Luke 42239 Posted October 26, 2021 Posted October 26, 2021 17 minutes ago, jachin99 said: I disabled playon, and i still get the same result. I'm looking for new plugins to show up in programdata/plugins. Is that right? Are there any network settings I need to look at in emby? Then the other thing to look at might be security software on the machine, but essentially the problem is the download is not succeeding, which makes it appear as though it's being blocked.
jachin99 88 Posted October 27, 2021 Posted October 27, 2021 IlI peek around the machine and see if I find anything
Luke 42239 Posted October 27, 2021 Posted October 27, 2021 3 hours ago, jachin99 said: IlI peek around the machine and see if I find anything Let us know how you get on. Thanks.
jachin99 88 Posted October 27, 2021 Posted October 27, 2021 I poked around and didn't find anything. Would something like Wireshark help track things down? Does anyone else have experience. Heading these kinds of issues?
jachin99 88 Posted October 28, 2021 Posted October 28, 2021 Is there a web address I can go to where I can grab plugins outside of emby server
jachin99 88 Posted November 7, 2021 Posted November 7, 2021 (edited) It looks like I had to pay closer attention to the assembly name. I was looking for Frontview but the plugin name starts with mediabrowser. Either way the client app is giving me a bad remote parameters error. I have already checked my firewall settings at least. I also looked for the log file for frontview in my program files directory. @GlennNZ is there any thing you need from me to help figure this out? Where can I grab a log from if need be? Thanks. Edited November 7, 2021 by jachin99
jachin99 88 Posted November 7, 2021 Posted November 7, 2021 [00:12:38.3987] FrontView+Api-EMBYAPI: : Test connection : 192.168.29.48:8096 [00:12:38.4416] FrontView+Api-EMBYAPI: : -------------------------Getting Emby TOKEN---------------------------------- [00:12:38.6101] FrontView+Api-EMBYAPI: : MediaBrowser Client="FrontView+", Device="Windows Application", DeviceId="9DA94EFB-EFF0-4144-9A18-46B046C450C6", Version="1.125", UserId="Family" [00:12:39.3891] FrontView+Api-EMBYAPI: : Emby Connection Failed : http://192.168.29.48:8096/mediabrowser/Users/AuthenticateByName [00:12:39.3911] FrontView+Api-EMBYAPI: : ExceptionSystem.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.GetResponse() at Remote.Emby.Api.Xbmc.GetEmbyAuthToken(String ip, String port, String user, String password) I found the log, here it is. FrontView+.log
GlennNZ 92 Posted November 7, 2021 Author Posted November 7, 2021 45 minutes ago, jachin99 said: [00:12:38.3987] FrontView+Api-EMBYAPI: : Test connection : 192.168.29.48:8096 [00:12:38.4416] FrontView+Api-EMBYAPI: : -------------------------Getting Emby TOKEN---------------------------------- [00:12:38.6101] FrontView+Api-EMBYAPI: : MediaBrowser Client="FrontView+", Device="Windows Application", DeviceId="9DA94EFB-EFF0-4144-9A18-46B046C450C6", Version="1.125", UserId="Family" [00:12:39.3891] FrontView+Api-EMBYAPI: : Emby Connection Failed : http://192.168.29.48:8096/mediabrowser/Users/AuthenticateByName [00:12:39.3911] FrontView+Api-EMBYAPI: : ExceptionSystem.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.GetResponse() at Remote.Emby.Api.Xbmc.GetEmbyAuthToken(String ip, String port, String user, String password) I found the log, here it is. FrontView+.log 1.24 MB · 2 downloads Basically Frontview is not authenticating using the password &/or email and password details you have provided. There isn’t anything more to it. I would check this thread for best username etc, and setup etc. this isn’t my usage and I can’t recall details. Alternatively it is possible there have been some changes on Emby’s end on this front, which FV is failing on.. but no ETA when I have a chance to look.
jachin99 88 Posted November 7, 2021 Posted November 7, 2021 @Luke. Has authentication changed over the last year or so? It looks like it was working as of November of last year.
jachin99 88 Posted November 7, 2021 Posted November 7, 2021 2021-11-07 00:13:42.006 Info Server: http/1.1 POST http://192.168.29.48:8096/mediabrowser/Users/AuthenticateByName. Content-Type=application/json; charset=utf-8, Expect=100-continue, Host=192.168.29.48:8096, Content-Length=178, X-Emby-Authorization=MediaBrowser Client="FrontView+", Device="Windows Application", DeviceId="9DA94EFB-EFF0-4144-9A18-46B046C450C6", Version="1.125", UserId="" 2021-11-07 00:13:42.358 Error UserManager: Error authenticating with provider Default *** Error Report *** Version: 4.7.0.17 Command line: C:\Users\Family\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19041 Framework: .NET Core 3.1.19 OS/Process: x64/x64 Runtime: C:/Users/Family/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\Family\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Family\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: Invalid username or password.. at Emby.Server.Implementations.Library.DefaultAuthenticationProvider.Authenticate(String username, String password, User resolvedUser) at Emby.Server.Implementations.Library.UserManager.AuthenticateWithProvider(IAuthenticationProvider provider, String username, String password, User resolvedUser, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: System.Threading.Tasks.Task`1[MediaBrowser.Controller.Authentication.ProviderAuthenticationResult] Authenticate(System.String, System.String, MediaBrowser.Controller.Entities.User) It looks like this is what is happening in emby?
Luke 42239 Posted November 7, 2021 Posted November 7, 2021 1 hour ago, jachin99 said: @Luke. Has authentication changed over the last year or so? It looks like it was working as of November of last year. No, but maybe it's using our legacy auth params from years ago? That's all I can think of.
