GlennNZ 92 Posted July 7, 2018 Author Posted July 7, 2018 Ok what you need to do is update to the latest beta nuget package, then recompile the plugin and it should be fine at that point. Then you can publish a plugin update with 3.4.1.27 as the min required server version. That error was with the latest beta nuget (62?) unless you have recently fixed? Glenn Sent from my iPhone using Tapatalk
Luke 42241 Posted July 7, 2018 Posted July 7, 2018 It doesn't sound like you've actually updated nuget. Try restarting visual studio.
GlennNZ 92 Posted July 8, 2018 Author Posted July 8, 2018 It doesn't sound like you've actually updated nuget. Try restarting visual studio. Ok - thanks Have restart Studio - and shows 3.3.38 Installed... Using CLI to reinstall Beta 3.3.62beta MediaBrowser.Server.Core Fails with error Install-Package : Package MediaBrowser.Common 3.3.62-beta is not compatible with netstandard1.3 (.NETStandard,Version=v1.3). Package MediaBrowser.Common 3.3.62-beta supports: netstandard2.0 (.NETStandard,Version=v2.0) Presume NetCore1.3 (still listed in wiki and target) is no longer compatible? This is the likely reason for the failure to install 3.3.62 - even though with Nuget Package Manager - did install and compile without error message. Presume I edit the Project cs file - as I did so in the Wiki and can't alter now from within Visual Studio? Glenn
Luke 42241 Posted July 8, 2018 Posted July 8, 2018 Yea edit the project cs and change from netstandard 1.3 to 2.0. Then you'll be able to update nuget. Thanks.
GlennNZ 92 Posted July 27, 2018 Author Posted July 27, 2018 New Version 1.285- Changes Weather API to DarkSky.net API (given Weather underground has closed down their API)Needs a DarkSky API key; available from DarkSky Free. (allows 1000 calls/day should be plenty)- Adds check for Currently screen if not displayed and should be- Weather path check- 32bit and 64bit versions of FrontView available.Installation:Acquire new DarkSky.Net Api Key from here:https://darksky.net/dev/registerInstall FrontView+ either 32 or 64 bit version. Go to Weather Settings Enter Latitude and Longitude of your location Enter Desired Name/Location ID (can be anything)Enter API KeyWeather Temp Units - as per DarkSKY APIAuto would seem best option. Click Save and Wait or Restart Application. Glenn Additionally: FrontView+ Emby Plugin is updated to version 2.0.53 (in plugin store - should automatically update) Functioning well currently with Beta Emby Server Version 3.6.0.2
jachin99 88 Posted September 7, 2018 Posted September 7, 2018 Can this show what is currently playing on a Emby for Windows Media Center Client. Sorry for such a simple question but a search of the thread didn't give me too many clues. Thanks.
GlennNZ 92 Posted September 7, 2018 Author Posted September 7, 2018 Can this show what is currently playing on a Emby for Windows Media Center Client. Sorry for such a simple question but a search of the thread didn't give me too many clues. Thanks. No problem. In Emby’s case yes it should work and show nowPlaying screens for any client - windows, android, iPad, etc. (this is because emby unlike some of the other media plug-ins is server/client rather than direct to client. If emby server displays info about the WMC plugin like any other client it should work) Obvious FrontView+ software is windows only though! Glenn
jachin99 88 Posted September 7, 2018 Posted September 7, 2018 (edited) The PC cas I am building for this will only have emby clients installed on it. Sorry again but I want to be absolutely sure the screen does not only work on a case in which emby server has been installed. Thanks again EDIT: I think I have it now. "In Emby's case" can be taken one of two was in this instance so I wasn't quite sure. Edited September 7, 2018 by jachin99
GlennNZ 92 Posted September 7, 2018 Author Posted September 7, 2018 The PC cas I am building for this will only have emby clients installed on it. Sorry again but I want to be absolutely sure the screen does not only work on a case in which emby server has been installed. Thanks again EDIT: I think I have it now. "In Emby's case" can be taken one of two was in this instance so I wasn't quite sure. Hi again FrontView+ needs to connect to a Emby Server. After that it will display information for any Emby client. Ideally that should be server should be on local network. But just to clarify - You are building new PC using 'Windows Media Center'? The same WMC that was discontinued in 2009? I'm not sure I would suggest this as the best way forward in 2018 Glenn
jachin99 88 Posted September 7, 2018 Posted September 7, 2018 I might but I haven't decided yet. Its a toss up between WMC & Kodi at this point. WMC is familiar to me, and I still like its simplicity. Maybe this will be easier if I explain in more detail. I have two machines. Machine 1 is a headless server with Emby server installed. I would obviously have to install the server plugin on this Machine 2 will be a media center PC (Either Kodi, or WMC) with the appropriate emby client installed, and will have the actual display. So I would want to view the media currently playing on Machine 2 via either a WMC or Kodi emby client. Will this work or do I need to have an instance of Emby Server on Machine 2 as well? Sorry for all of the confusion.
GlennNZ 92 Posted September 7, 2018 Author Posted September 7, 2018 I might but I haven't decided yet. Its a toss up between WMC & Kodi at this point. WMC is familiar to me, and I still like its simplicity. Maybe this will be easier if I explain in more detail. I have two machines. Machine 1 is a headless server with Emby server installed. I would obviously have to install the server plugin on this Machine 2 will be a media center PC (Either Kodi, or WMC) with the appropriate emby client installed, and will have the actual display. So I would want to view the media currently playing on Machine 2 via either a WMC or Kodi emby client. Will this work or do I need to have an instance of Emby Server on Machine 2 as well? Sorry for all of the confusion. Ok: You only need one Emby Server which can serve multiple clients. Machine 1 Machine 2 <Server> ------------------------------ <Client1> Plugin Installed \ FrontView+ installed \ Displaying Info from this client \ \ Machine 3 <Client2> 1
jachin99 88 Posted September 7, 2018 Posted September 7, 2018 Got it, thanks for the help Sent from my Pixel XL using Tapatalk
jachin99 88 Posted November 1, 2018 Posted November 1, 2018 Is there a way to calibrate the touchscreen via Frontview +? If not what can I use to do so that is compatible with Win 7? The discs that came with my case look like they are for XP. I found a version of the IMon software that is compatible with 7 but it doesn't include a calibration utility, and right now the touch controls for the screen are inverted. Thanks.
HCIchus 0 Posted January 22, 2019 Posted January 22, 2019 Hi, Thank you very much for this good tool and the work that has been done. Actually, everything works fine, unfortunately I can not manage the weather. Can you please help me, what am I doing wrong. Thank you so much for your time and help. greetings Christian <IPPort>5000</IPPort> <IPAddress>127.0.0.1</IPAddress> <Skin>EmbySkin Default</Skin> <WeatherLoc>Munich, Bavaria</WeatherLoc> <WeatherLongitude>11.5754</WeatherLongitude> <WeatherLatitude>48.1371</WeatherLatitude> <WeatherAPI>11111a28f****48a64435861e</WeatherAPI> <WeatherUnit>auto</WeatherUnit> <Homepage>Weather</Homepage>
GlennNZ 92 Posted January 22, 2019 Author Posted January 22, 2019 (edited) Hi, Thank you very much for this good tool and the work that has been done. Actually, everything works fine, unfortunately I can not manage the weather. Can you please help me, what am I doing wrong. Thank you so much for your time and help. greetings Christian> Hi,Glad everything’s working I might need debug log to figure it out - it’s the %appdata%/FrontView directory. May have a fairly obvious error within in. Missing the log, and at first guess - it may be the comma in the Weather location ID? Would remove the comma and change to: Munich Bavaria alone and see whether that fixes? The weather location Id is just a name that is given to this location, it is not used for any of the weather data - so could name it Home or whatever suits. Glenn Sent from my iPad using Tapatalk Edited January 22, 2019 by GlennNZ
HCIchus 0 Posted January 23, 2019 Posted January 23, 2019 (edited) Thank you for your help ! Unfortunately, your tips have so far brought no success. Enclosed as desired nor the log file. greetings Christian FrontView+.log Edited January 23, 2019 by HCIchus
HCIchus 0 Posted January 23, 2019 Posted January 23, 2019 Hi Glad, Once again, thank you very much for your help. I found the mistake The API was invalid, I got a new one and now everything works. Little Donate is on his way to you. greetings Christian
jachin99 88 Posted March 1, 2019 Posted March 1, 2019 I reinstalled windows, and had to reinstall Emby server, and frontview + along with its emby plugin. I can't seem to get FV+ to show any kind of data. I updated my location for example but I still get no weather data, and It gives me a bad parameters message when I try pointing it to emby server. I'm using my emby server address, getting the mac from the IP, and using port 8096. I tired disabling my firewall with no luck, and I allow frontview through my fiewall as an app but also still no luck. What could I be doing wrong? I also configured the emby server plugin to point at my desired client. I also seem to remember setting up an API key for emby the last time I did this but I can't find that option anywhere now. Thanks for the help.
GlennNZ 92 Posted March 2, 2019 Author Posted March 2, 2019 (edited) I reinstalled windows, and had to reinstall Emby server, and frontview + along with its emby plugin. I can't seem to get FV+ to show any kind of data. I updated my location for example but I still get no weather data, and It gives me a bad parameters message when I try pointing it to emby server. I'm using my emby server address, getting the mac from the IP, and using port 8096. I tired disabling my firewall with no luck, and I allow frontview through my fiewall as an app but also still no luck. What could I be doing wrong? I also configured the emby server plugin to point at my desired client. I also seem to remember setting up an API key for emby the last time I did this but I can't find that option anywhere now. Thanks for the help. OK, well it is obviously something you haven't set up. 1. Weather is separate to FrontView receiving Embys info - need to setup Weather API for that. 2. Probably from the sound of it you have the settings wrong for your Emby remote connection: There is an manual which still covers all of this. You do need at least local firewall access. The remote settings are the Emby IP address and port e.g 192.168.1.209:8096 No need for the MAC address - just use the IP address You need to make sure have selected Emby as type of connection. You'll need a Emby local user/password for the user/password bit or a user without a password (just leave password blank if isn't one is also fine) 3. There is no Emby API key etc. needed If you try http://EmbyServerIP:EmbyPort/Frontview/ in a web browser - you should get some info, and this should change when client is playing. Going through above - probably seems like haven't entered Emby User password details correctly. Failing the above, or just figuring it out, could try attaching a log? Can confirm is working on server 4.1.0.11 G Edited March 2, 2019 by GlennNZ
jachin99 88 Posted March 4, 2019 Posted March 4, 2019 (edited) I'm on server version 4.0.2.0. I typed in MYIP:8096/Frontview, and I get a response but I haven't checked with media playing. I believe I have enabled all of the necessary server settings but I'll have to look again. I'll attach logs, and take a detailed look tomorrow but I didn't want to go too long without responding to your help. Thanks again, and I'll get back to you with logs, etc. Edited March 4, 2019 by jachin99
GlennNZ 92 Posted March 4, 2019 Author Posted March 4, 2019 I'm on server version 4.0.2.0. I typed in MYIP:8096/Frontview, and I get a response but I haven't checked with media playing. I believe I have enabled all of the necessary server settings but I'll have to look again. I'll attach logs, and take a detailed look tomorrow but I didn't want to go too long without responding to your help. Thanks again, and I'll get back to you with logs, etc. Likely issue will be the Emby username/password - create a new local user if needed. G Sent from my iPad using Tapatalk
jachin99 88 Posted March 5, 2019 Posted March 5, 2019 I created a new local users, and tried that but I'm still not having much luck. I haven't tried enabling emby connect on this server because I use that on a different server. I enabled debug logging, and I'm attaching that. I'm not sure if some update in my newer version of emby server is causing issues or what but I don't have a lot of experience with frontview to draw any conclusions from. Once again I appreciate the help. FrontView+.log
GlennNZ 92 Posted March 5, 2019 Author Posted March 5, 2019 (edited) I created a new local users, and tried that but I'm still not having much luck. I haven't tried enabling emby connect on this server because I use that on a different server. I enabled debug logging, and I'm attaching that. I'm not sure if some update in my newer version of emby server is causing issues or what but I don't have a lot of experience with frontview to draw any conclusions from. Once again I appreciate the help.Thanks for the log - does show error when try’s to connect to Emby. The returned data from Emby isn’t correct. Not quite sure why. I’m away at moment so can’t really test proper connection. I’m on latest beta 4.1.0.12 or so server - which is newer than yours. Otherwise might be a http:// security Emby setting - frontview only uses http not https. Will check Emby documentation. Check Emby settings/advanced Secure connection mode: Ideally should be disabled. Sent from my iPad using Tapatalk Edited March 5, 2019 by GlennNZ
jachin99 88 Posted March 5, 2019 Posted March 5, 2019 Thanks, and I'll take a look. I'm not in a rush so I can wait for you to have a good look at it.
jachin99 88 Posted March 5, 2019 Posted March 5, 2019 (edited) Dont waste any time looking at this just yet. I might have figured things out. EDIT: Yep, i got it fixed. I was on an old version. Edited March 5, 2019 by jachin99
