Iorifly 15 Posted February 6, 2016 Posted February 6, 2016 (edited) Friends, I have a strange problem ... I can not upgrade to version "3.0.5818.0 MBServer" always restart the Emby after downloading this version and it does not automatically start, I have to open the program manually. However the download begins again and is in that cycle. I need help, my Emby is always asking to restart to install this version and never installed. I am running Emby the way: "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\system" My system: Windows 8.1 My log http://pastebin.com/r98srD8a server-63590353526.txt Edited February 6, 2016 by Iorifly
CBers 7541 Posted February 6, 2016 Posted February 6, 2016 http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/
Iorifly 15 Posted February 6, 2016 Author Posted February 6, 2016 (edited) Can anyone help me effectively? Posted log and all. This problem is impeding the use of Emby. I would not want to do a fresh install, because I have many configurations and film. The last time I tried did not recover the backup, I had to start all over from scratch work. Edited February 6, 2016 by Iorifly
Solution Luke 42186 Posted February 6, 2016 Solution Posted February 6, 2016 Hi lorifly, what I would try doing is shutting down the server, then getting the update by installing it from the website. Let us know if that resolves the issue. Thanks. 2
Happy2Play 9800 Posted February 7, 2016 Posted February 7, 2016 Some systems have an issues where the server process hangs and the update process fail to get control of the system folder to change it to .old and add the new system folder. Unfortunately the only recourse is shutting down the server and waiting for the process to die off and manually update. If this is the issue you are having. 1
Iorifly 15 Posted February 7, 2016 Author Posted February 7, 2016 luke, Thank you! Solved with an installation above the other.
