h45e 1 Posted February 6, 2016 Posted February 6, 2016 Hi, I am trying to install live TV, I have installed DVB logic, and that side works, but it doesnt work on emby theater, here are my logs and some screen shots. DVBLogic Emby Server settings Emby Theater Emby logs.rtf
Luke 42241 Posted February 6, 2016 Posted February 6, 2016 Hi, welcome. What is the issue? have you tried refreshing the guide data?
MadibaJ 20 Posted February 6, 2016 Posted February 6, 2016 Have you got the dvb logic plugin installed?
h45e 1 Posted February 6, 2016 Author Posted February 6, 2016 Hi, Refreshed the guide. Reinstalled the plugin. It does come up with the channels in the guide now, but no EPG. I am in Perth, Australia.
Latchmor 584 Posted February 6, 2016 Posted February 6, 2016 Not sure if this is related to the issue or not but your image shows one HD with http:// and one without. Both mine show http:// (I can't remove to test as they are in use just now)
Guest asrequested Posted February 6, 2016 Posted February 6, 2016 It looks like you need to enter a guide provider.
Luke 42241 Posted February 6, 2016 Posted February 6, 2016 No, if he's using the DVB plugin, then the plugin is responsible for the guide.
