MrGenius1 3 Posted February 5, 2016 Posted February 5, 2016 Ok I have placed this issue in its own thread. Maybe that is what i was missing on why i haven't received a response. I want to get the system back up and running for the weekend. I have a few people coming over for the game. After the database upgrade from 3.0.5863 everything was working great. Update 3.0.5864 just showed the database html page with no progress. Update 3.0.5865 shows a blank page but the tab header says "Waiting on localhost" I have attached the log files and I am hoping someone can assist me with getting this corrected. Emby-InstallLogs.zip
Luke 42186 Posted February 6, 2016 Posted February 6, 2016 Hi, I would suggest going here C:\Users\Administrator\AppData\Roaming\Emby-Server\plugins And deleting your plugin dlls. Then I would go to C:\Users\Administrator\AppData\Roaming\Emby-Server\root\default Find the .mblink file that is pointing to \\GENIUSMGI-2\GeniusMGI (G) and delete it. then try to start the server. It really shouldn't be necessary to do either of these things, but they're good things to try given that we're not sure what the issue is yet. Let me know how it goes. Thanks.
Solution Luke 42186 Posted February 6, 2016 Solution Posted February 6, 2016 Actually I found the issue. I think your best course of action is going to be deleting this file C:\Users\Administrator\AppData\Roaming\Emby-Server\data\library.db And letting the server rebuilt it. That means a full library scan will happen. The stable version doesn't understand the database changes introduced by beta, and now that you've gone back and forth there are some issues here. The things I mentioned in the previous post are not necessary, but may help simplify things. 1
MrGenius1 3 Posted February 6, 2016 Author Posted February 6, 2016 Thank you Luke, Deleting the library.db file brought the system up. Scan is happening as I'm typing this. Also deleted two .mdlink files. Not sure why they were still in there. Those drives have been removed from the system over six months ago. Again thank you for your help. Soon the family will be off my back and able to get back to their stuff! 1
