skank 85 Posted February 5, 2016 Posted February 5, 2016 Yesterday i tried to play a movie, but it said it wasnt there anymore and he asked to remove it from library Any idea why this happens? Everything was there and ok.. server running etc etc Think i'm on 2.0.1
Angelblue05 4132 Posted February 5, 2016 Posted February 5, 2016 Is it all of them doing this? Are you sure the path is still accessible?
skank 85 Posted February 5, 2016 Author Posted February 5, 2016 yeah, i didnt change a thing in path Nothing changed, except an update of the kodi emby app
Angelblue05 4132 Posted February 5, 2016 Posted February 5, 2016 (edited) You could try to run a reset to see if it fixes your issue. Maybe your paths got corrupted somehow? Otherwise, for some reason, Kodi is complaining that it's unable to locate your content... Verify your file permissions, make sure your network credentials are entered, in they are needed. There's nothing in the add-on updates that would mess with your database. Nothing has been changed in that area in a while. Edited February 5, 2016 by Angelblue05
skank 85 Posted February 5, 2016 Author Posted February 5, 2016 Nothing changed to file permissions, i dont need network credentials to access them either very change, resync might do the trick but arhg that takes time lol will do tonight thx 1
Angelblue05 4132 Posted February 5, 2016 Posted February 5, 2016 (edited) You can check your paths by opening the info dialog on the content in Kodi. It should display under Path. Does it look correct? Edited February 5, 2016 by Angelblue05
