Zeddd 0 Posted February 4, 2016 Posted February 4, 2016 I'm hoping someone can help or point me in the right direction. Sorry if this is not the right place Here is what i'm looking to do. I open on my computer a live video stream that comes into me for example via .m3u. What id like to do is then re broadcast that stream out to someone else but through my connection instead of the original .m3u. So essentially the live stream comes in to me as i download it I upload it out to someone else. I understand there will be a delay as i download and stream out and i'm sure there will probably be quality lost but i'm willing to live with that. Not sure if there is a plugin that does this but that would be even more awesome Thanks in advance for the help.
Luke 42242 Posted February 4, 2016 Posted February 4, 2016 Hi, welcome. Yes I think you can probably do this by adding the IPTV plugin: https://github.com/MediaBrowser/Wiki/wiki/Plugins Then, you can add the stream to the plugin's configuration which will allow you to play that content within emby apps. Does that answer your question?
Zeddd 0 Posted February 4, 2016 Author Posted February 4, 2016 Hi, welcome. Yes I think you can probably do this by adding the IPTV plugin: https://github.com/MediaBrowser/Wiki/wiki/Plugins Then, you can add the stream to the plugin's configuration which will allow you to play that content within emby apps. Does that answer your question? Yes that answers part of my question. I still need to find the way to rebroadcast the orginal stream but i'm finding there may be some options using ffmpeg,vlc or a software called Action!
