Happy2Play 9811 Posted February 4, 2016 Posted February 4, 2016 I can set a Easy Pin number and change the pin, but I am unable to remove and save "no pin", for local access. Already messed up a couple accounts testing this, they now require pin or password to log in locally. Not specific to Official or Beta, didn't test on dev.
Happy2Play 9811 Posted February 4, 2016 Author Posted February 4, 2016 (edited) Clicking reset password in the dashboard clears everything on screen to allow entering a new password, once new password is entered the Easy Pin is still populated with previous pin. Edited February 4, 2016 by Happy2Play
Happy2Play 9811 Posted February 7, 2016 Author Posted February 7, 2016 Only way I have found to remove/reset pin to "no pin" is deleting and re-adding the user, then restoring userdata via plugin.
Luke 42241 Posted February 7, 2016 Posted February 7, 2016 This whole feature is actually going to go away at some point. We're going to replace it with an equivalent of the emby connect pin code sign in, which won't require any pre-requisite setup at all.
Happy2Play 9811 Posted February 7, 2016 Author Posted February 7, 2016 Hmm never thought to look there. Is this new or has it always been in Connect? Web Client Emby Connect
Luke 42241 Posted February 7, 2016 Posted February 7, 2016 No what I mean is the pin process that is part of the startup wizard for TV based apps like seeing theater and roku
ebr 16334 Posted February 7, 2016 Posted February 7, 2016 This whole feature is actually going to go away at some point. We're going to replace it with an equivalent of the emby connect pin code sign in, which won't require any pre-requisite setup at all. The PIN process we use with Connect is a one-time operation and, after that, it is remembered and not needed again. This PIN is entirely different as it is simply a replacement for a password that is too cumbersome to be entered with a remote control but that still needs to be entered on each application start. 1
Happy2Play 9811 Posted February 22, 2016 Author Posted February 22, 2016 Am I the only one that doesn't see a reset option in the web client as shown in post #6? I checked IE, Edge, Chrome and Firefox. v3.0.5884.0
Happy2Play 9811 Posted February 25, 2016 Author Posted February 25, 2016 (edited) Now the option has been removed from Connect to reset Easy Pin. So one is forced to delete and recreate user to remove pin. Edited February 25, 2016 by Happy2Play
Happy2Play 9811 Posted March 3, 2016 Author Posted March 3, 2016 (edited) @@Luke, I can reset Easy Pin via myprofile.html but not userpassword.html. Looks like the difference is (style="display:none;") in userpassword.html. https://github.com/MediaBrowser/Emby/blob/fdd93ce88b4a9e583e8ea12b98f21d16c0425bc2/MediaBrowser.WebDashboard/dashboard-ui/myprofile.html#L103 https://github.com/MediaBrowser/Emby/blob/fdd93ce88b4a9e583e8ea12b98f21d16c0425bc2/MediaBrowser.WebDashboard/dashboard-ui/userpassword.html#L75 Edited March 3, 2016 by Happy2Play
