thefirstofthe300 292 Posted February 3, 2016 Posted February 3, 2016 (edited) If you click more reply options next to the post button, you should have an option to attach files. If the file size is still too big, you should be able to compress it to get it down to size as it is just all text. But Drive works too. Edited February 3, 2016 by thefirstofthe300
thefirstofthe300 292 Posted February 3, 2016 Posted February 3, 2016 That looks much better. Those pings appear to be from the DLNA server so if you don't use DLNA, turning it off should do a lot to reduce the log file's size. Also, you still seem to be getting a couple of errors due to permissions problems. They seem to affect Big Hero 6 and Go Panda, so you want to check the permissions on those folders and the files in those folders. It is only those two movies though so I doubt it is a huge issue. Luke will have to help you with the Live TV stuff. Hopefully he can get you sorted out.
haeffnkr 3 Posted February 3, 2016 Author Posted February 3, 2016 OK I turned off DLNA, thanks... I deleted the garbage .nfo files emby was trying to get information on, thanks. 1
haeffnkr 3 Posted February 4, 2016 Author Posted February 4, 2016 (edited) This log file was from 2/1 when there was a successful couple of recordings - https://drive.google.com/file/d/0ByrtBHddN3ZIU21FX0hvb29xNDA/view?usp=sharing Hope this helps... can someone look at "recordings" and find a successful one vs one that errors and let me know how to resolve please? thanks in advance haeffnkr I pulled some data out of the file - Working Recording - 2016-02-01 23:36:49.2721 Info App: Recording timer fired. 2016-02-01 23:36:49.3282 Info App: Streaming Channel hdhr_36 2016-02-01 23:36:49.3334 Info App: GetChannelStream: channel id: hdhr_36. stream id: 2016-02-01 23:36:49.3365 Info App: New recording scheduled 2016-02-01 23:36:49.3373 Info HttpServer: HTTP Response 204 to 192.168.5.126. Time: 230ms. http://192.168.5.126:8096/emby/LiveTv/Timers 2016-02-01 23:36:52.3371 Info App: Beginning recording. Will record for 23.1277679 minutes. 2016-02-01 23:36:52.3371 Info App: Writing file to path: /var/lib/emby-server/data/livetv/recordings/Sports/Women's College Basketball/Women's College Basketball 2016-02-02 SP003341900000T635899824000000000C36.ts 2016-02-01 23:36:52.3371 Info App: HttpClientManager GET: http://192.168.5.123:5004/auto/v36 2016-02-01 23:36:52.8830 Info HttpServer: HTTP GET http://192.168.5.126:8096/dlna/ff5bfa87f92fd97079076efc508137cd/description.xml. UserAgent: UPnP/1.0 2016-02-01 23:36:52.9024 Info HttpServer: HTTP Response 200 to 192.168.5.142. Time: 20ms. http://192.168.5.126:8096/dlna/ff5bfa87f92fd97079076efc508137cd/description.xml 2016-02-01 23:36:52.9103 Info HttpServer: HTTP GET http://192.168.5.126:8096/dlna/ff5bfa87f92fd97079076efc508137cd/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 This log came out of the next log file that I do not have linked.... 016-02-02 00:00:02.7102 Info App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Apartment+Troubles&language=en 2016-02-02 00:00:03.0095 Info App: HttpClientManager GET: http://api.themoviedb.org/3/movie/276906?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2016-02-02 00:00:03.0805 Info App: Beginning recording. Will record for 59.9486713166667 minutes. 2016-02-02 00:00:03.0805 Info App: Writing file to path: /var/lib/emby-server/data/livetv/recordings/Series/Law & Order/Law & Order S14E15 Veteran's Day.ts 2016-02-02 00:00:03.0808 Info App: HttpClientManager GET: http://192.168.5.123:5004/auto/v781 2016-02-02 00:00:03.8990 Info App: HttpClientManager GET: http://www.omdbapi.com/?plot=short&r=json&t=The+Plague&type=movie 2016-02-02 00:00:03.9620 Info App: MovieDbProvider: Finding id for item: The Plague 2016-02-02 00:00:03.9620 Info App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+Plague&language=en 2016-02-02 00:00:04.2625 Info App: HttpClientManager GET: http://api.themoviedb.org/3/movie/271223?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_im After this recording I have not had any success. Failed Recording - 2016-02-03 12:30:00.0037 Info App: Recording timer fired. 2016-02-03 12:30:00.0706 Error App: Error recording stream *** Error Report *** Version: 3.0.5821.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.13.0.37 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 19:03:13 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Value cannot be null. Parameter name: source System.ArgumentNullException at System.Linq.Enumerable.FirstOrDefault[TSource] (IEnumerable`1 source, System.Func`2 predicate) <0x412ca8f0 + 0x0013f> in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV+<RecordStream>c__asyncD.MoveNext () <0x42017c60 + 0x00b2b> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x7f4de3f666d0 + 0x00029> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x7f4de3f646b0 + 0x000a7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x7f4de3f64630 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x7f4de3f645e0 + 0x0003a> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () <0x7f4de3f64b10 + 0x00012> in <filename unknown>:0 at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV+<_timerProvider_TimerFired>c__asyncC.MoveNext () <0x414406f0 + 0x0067e> in <filename unknown>:0 What does this mean ???? - Value cannot be null. -- What value? where? So it appears that if the recording is set on a timer, the timer fires and the app is to pull the channel from my hdhomerun prime tuner, but appears to fail to get the stream? Why? Nothing wrong with the hdhomerun... has been up for months and I have no issues playing channels live directly from VLC or Emby. Please help haeffnkr Edited February 4, 2016 by haeffnkr
haeffnkr 3 Posted February 5, 2016 Author Posted February 5, 2016 Can someone please help me resolve this issue? thanks in advance haeffnkr
haeffnkr 3 Posted February 7, 2016 Author Posted February 7, 2016 Can anyone please help me with this issue? I bought android apps expecting to to use this emby backend as my main dvr as it is supposedly supported with hdhomerun but it does not work at the most basic level. Thoughts suggestions help ???? Also I sent a pm to fc7 who suggested that I continue this comical post as he can not help me with any live tv issues. Luke suggested I post mulitpe logs but can not tell me why I see to see/have continue to see errors.
haeffnkr 3 Posted February 9, 2016 Author Posted February 9, 2016 Can anyone suggest some changes? What value is null that the program is looking for? thanks haeffnkr
Luke 42243 Posted February 9, 2016 Posted February 9, 2016 I apologize, I will go over all of this soon. In the meantime, what linux distro are you on? Can you try the beta branch? Thanks.
haeffnkr 3 Posted February 11, 2016 Author Posted February 11, 2016 Linux Mint 17.1 - running ubuntu 14.04 emby app. What beta branch app?
Luke 42243 Posted February 11, 2016 Posted February 11, 2016 the beta branch for ubuntu is here: https://emby.media/download/ although i'm not sure you can upgrade from stable. @@fc7 can elaborate. we'll have a new stable release out soon.
haeffnkr 3 Posted February 11, 2016 Author Posted February 11, 2016 OK I will wait for the stable release. What about my error ? what is causing it? haeffnkr
Luke 42243 Posted February 11, 2016 Posted February 11, 2016 Those I'm looking into for the upcoming release.
haeffnkr 3 Posted February 11, 2016 Author Posted February 11, 2016 What is upcoming in this release that you feel will fix my issue?
fc7 123 Posted February 11, 2016 Posted February 11, 2016 the beta branch for ubuntu is here: https://emby.media/download/ although i'm not sure you can upgrade from stable. @@fc7 can elaborate. we'll have a new stable release out soon. You can't. You need to remove emby-server package from your distro and install emby-server-beta instead. It's a pretty easy process. For Ubuntu it should be something like: $ sudo apt-get remove emby-server $ sudo apt-get install emby-server-beta If you then want to go back to stable, just proceed the same way. Remove emby-server-beta and then install emby-server package. You Emby data will not be affected.
thefirstofthe300 292 Posted February 11, 2016 Posted February 11, 2016 Doesn't the latest beta have breaking changes in the database that prevents a downgrade? Or did that already get pushed to stable?
Luke 42243 Posted February 12, 2016 Posted February 12, 2016 it's still in beta, so that's correct, you shouldn't try to downgrade.
fc7 123 Posted February 12, 2016 Posted February 12, 2016 it's still in beta, so that's correct, you shouldn't try to downgrade. Oops. Sorry for the suggestion then. But in other cases where the DB will not be a stopper, the procedure is still good. BTW @@Luke, I didn't try the beta yet but is there a big red disclaimer that once installed you can't go back to stable until the next release? I'm wondering if users are aware enough about this detail.
haeffnkr 3 Posted February 21, 2016 Author Posted February 21, 2016 I upgraded to the latest release and nothing has changed, ie recording does not start. I try to view the logs from the web home page server - Server - Support - Logs page and the logs will not display. Can someone please tell me how to resolve this issue? haeffnkr
haeffnkr 3 Posted February 21, 2016 Author Posted February 21, 2016 (edited) https://drive.google.com/open?id=0ByrtBHddN3ZIUjNZOVg2RzNMU28 - log https://drive.google.com/open?id=0ByrtBHddN3ZISGx2d0swMVBnMkk - log Same errors.... null value... can some one please tell me what to do to resolve this or can you please connect me with someone who actually has this working on linux ubuntu so I can work with them directly? Edited February 21, 2016 by haeffnkr
Luke 42243 Posted February 21, 2016 Posted February 21, 2016 https://drive.google.com/open?id=0ByrtBHddN3ZIUjNZOVg2RzNMU28 - log https://drive.google.com/open?id=0ByrtBHddN3ZISGx2d0swMVBnMkk - log Same errors.... null value... can some one please tell me what to do to resolve this or can you please connect me with someone who actually has this working on linux ubuntu so I can work with them directly? Can you try running the refresh guide operation under the server configuration interface -> Live TV? After that, can you setup some brand new recordings and see how that goes? Thanks.
haeffnkr 3 Posted February 21, 2016 Author Posted February 21, 2016 (edited) Tell me why this would work to solve my issue? Edited February 21, 2016 by haeffnkr
Luke 42243 Posted February 21, 2016 Posted February 21, 2016 It shouldn't be necessary for most users but since you've been having issues I would like to test with fresh data
haeffnkr 3 Posted February 21, 2016 Author Posted February 21, 2016 It is scheduled to refresh once a day... but OK sure....
haeffnkr 3 Posted February 21, 2016 Author Posted February 21, 2016 (edited) Guide screen is blank now... want me to restart the server again? Finally popped up... never mind.... Edited February 21, 2016 by haeffnkr
haeffnkr 3 Posted February 22, 2016 Author Posted February 22, 2016 More logs - https://drive.google...azFXb0EyTkJxNUU I tried to record 2 more shows... one I started and one I scheduled... both have the same error... the same error that no one knows how to fix 2016-02-21 19:29:59.9993 Info App: Recording timer fired. 2016-02-21 19:30:08.6395 Error App: Error recording stream *** Error Report ***.................................................. The app is supposed to find the tuner first but it does not ... WHY !!!! ????? I have spent more time providing logs than it would have taken to setup mythtv. But this emby app seems to have promise... at least it looks great so I keep playing with it.... only to get more frustrated. I can not get upgrade to the premiere and buy more client apps until the DVR works... please. Please help.
