Getumzz 13 Posted January 31, 2016 Posted January 31, 2016 Hey, Just want to start off by saying thank you for a really amazing update on ET. Been waiting for this forever. So to the issues I got. First some how I have lost the option to use EVR. I got EVR+ and MADVR on the list but not the EVR like i normally did. Don't know if I just need to reinstall ET or if there is an issue at the moment with it. Second issue. I can't uncheck an episode as watched or even mark it as watched. There is an option to mark a whole season as watched or unwatched. Third issue. If I'm opening the menu for all series and want to back out one step it takes me to the start screen in my case it's Movies and I have to navigate back to my overview for the tv-shows I got. For example, If I open the menu all series, picka show and watch an episode then stops it and hit back it takes me to the show. Hitting back again takes me to the all shows view and hitting back again takes me to the overview for what ever is first in the menu. Is there a way to solve this so if/when i hit back I just go back to the tv-show overview and not back to main overview. And don't tell me to change the order of the menu, still the same if I change it and backs out from all movies it takes me to the main screen for what ever is first on the menu. Once again, thank you for an awesome update. MT ver. 1.0.39
Happy2Play 9811 Posted January 31, 2016 Posted January 31, 2016 For your second issue you have to get to the episode to change watched status. Season level Episode level (not sure on remote controls, but right arrow on episode at season level moves to individual episode)
Getumzz 13 Posted February 1, 2016 Author Posted February 1, 2016 (edited) For your second issue you have to get to the episode to change watched status. Season level Episode level (not sure on remote controls, but right arrow on episode at season level moves to individual episode) Well, if I pick an episode from "next up" I get that option.But if I go through "All series" and pick a show and then the season, it starts playing right away when I pick an episode. All I have is the option to mark the whole season as watch/unwatched. Edited February 1, 2016 by MrDon
Happy2Play 9811 Posted February 1, 2016 Posted February 1, 2016 I only know keyboard and mouse command, if you right click at season level it will highlight the episode then you use right arrow to move from season level to episode level. Don't know how this works with a remote. 2
Getumzz 13 Posted February 1, 2016 Author Posted February 1, 2016 I only know keyboard and mouse command, if you right click at season level it will highlight the episode then you use right arrow to move from season level to episode level. Don't know how this works with a remote. Ah there it is! Thanks, Happy. I had no idea about the right move on an episode.
Luke 42241 Posted February 2, 2016 Posted February 2, 2016 As far as EVR, it was removed so that we can focus all of our efforts on the EVR+ renderer, so whatever your actual issue with the renderer is, please let us know so that it can be resolved. Thanks. 1
Getumzz 13 Posted February 2, 2016 Author Posted February 2, 2016 As far as EVR, it was removed so that we can focus all of our efforts on the EVR+ renderer, so whatever your actual issue with the renderer is, please let us know so that it can be resolved. Thanks. No problem with EVR+, Luke Well part from madvr but that's something for another time. Was had a thought if my ET were messing or what was going on with EVR. But now I know and can stop thinking about it.
