Damstas 9 Posted January 30, 2016 Posted January 30, 2016 (edited) I have a HDHomerun Expand model, which has very similar hardware to USA counterpart Prime. When I pull the cords behind the unit lightly, I can hear that the hardware inside is moving a little. Do you guys, who have the Prime/Expand have a similar case? Edited January 30, 2016 by Damstas
Damstas 9 Posted January 30, 2016 Author Posted January 30, 2016 (edited) Edited January 30, 2016 by Damstas
pir8radio 1313 Posted January 31, 2016 Posted January 31, 2016 (edited) @@Damstas I Just checked, mine does the same thing. US Version (Prime). Looks like the internal PC board is not screwed down, its kind of sandwiched between the top and bottom case pieces. Looks to be normal. Edited January 31, 2016 by pir8radio
Damstas 9 Posted January 31, 2016 Author Posted January 31, 2016 @@Damstas I Just checked, mine does the same thing. US Version (Prime). Looks like the internal PC board is not screwed down, its kind of sandwiched between the top and bottom case pieces. Looks to be normal. Ok, thanks for checking it out!
