CFC 25 Posted January 30, 2016 Posted January 30, 2016 When I try to access offline mode, the app is still asking me for the pin, even though I cleared the password and pin off my profile. Is there a way I should also reset this in the app? Thanks, CFC
Luke 42239 Posted January 30, 2016 Posted January 30, 2016 did you try a blank pin? also it updates that info during the sync process so it might not be immediate
Solution CFC 25 Posted January 30, 2016 Author Solution Posted January 30, 2016 (edited) did you try a blank pin? also it updates that info during the sync process so it might not be immediate Yes, I tried just leaving it blank, but it denied access. I had to put in my old pin number to get through. Worked it out pretty quickly though. I signed out on the tablet, and signed back in and it was all good. I'd remove my password and pin quite a while ago, but hadn't needed to go offline since sync wasn't working properly until recently. CFC Edited January 30, 2016 by CFC
