duk 0 Posted January 28, 2016 Posted January 28, 2016 When I configure a mapped network drive in emby server it works fine the first time. But when my windiws 7 machine awakes from sleep I don't see any content anymore from this drive in emby. The logging says it can't connect because connection is refused. How come?
AdrianW 1058 Posted January 28, 2016 Posted January 28, 2016 It's really best not to use mapped drives. The preferred method is to use UNC paths (i.e. \\servername\sharename\foldername - e.g. \\MyNas\Videos\Movies).
Luke 42186 Posted January 29, 2016 Posted January 29, 2016 UNC is a good approach. Direct paths + path substitution is the best. But if you don't know what that means, then UNC is just fine. You can learn more on our library setup wiki: https://github.com/MediaBrowser/Wiki/wiki/Library%20Setup
ebr 16307 Posted January 29, 2016 Posted January 29, 2016 Just to re-enforce. Don't use mapped drives.
