mhuck0625 1 Posted January 28, 2016 Posted January 28, 2016 I am running Emby on a T310 server. 16gb RAM, windows server 2008, Xeon x3470 @2.93 ghz. It was even buffering over my LAN last night. The logs appear to show that it is processing around 29fps(if i am reading it correctly) I have fast internet(supposed to be 60 down, 5 up but i get around 20 down and 3-4 up.) Any help on this is greatly appreciated. Logs attached. logs.txt
mhuck0625 1 Posted January 28, 2016 Author Posted January 28, 2016 It appears to be working now! Thanks!
mhuck0625 1 Posted January 28, 2016 Author Posted January 28, 2016 I may have spoke too soon, it worked for an episode but now is back to buffering every few seconds.
legallink 187 Posted January 28, 2016 Posted January 28, 2016 What happens when you pause the playback? Does it play more fluidly for a while and then revert? Also, what device are you playing it on? And are there other processes running on your machine?
mhuck0625 1 Posted January 28, 2016 Author Posted January 28, 2016 It does work for a while after i pause and wait then it reverts back to every couple of seconds. I am playing it in google chrome over the internet. I dont have much running. I do use security essentials for antivirus(ive excluded the media browser service and the emby folder) i also have universal media server running(although the problem still occurs when it isnt. I installed it because i got frustrated when i couldnt figure out what was wrong with Emby-universal media server has no issues streaming on my LAN) Other than that i have dropbox, teamviewer and gateway IP monitor installed and running, none of which are processor or memory intensive. Hope that gives you an idea of my setup. Thanks!
Luke 42186 Posted January 28, 2016 Posted January 28, 2016 Please provide another sample log now that you have transcoding logging disabled.
mhuck0625 1 Posted January 28, 2016 Author Posted January 28, 2016 It seems like MP4 and AVI files play fine, but anything else(MKV, motroska, etc) are the ones having issues. logs attached logs.txt
mhuck0625 1 Posted January 29, 2016 Author Posted January 29, 2016 Are these the transcoding logs you are looking for? transcode-8c9d5561-3e9a-43c9-9c2c-39dace63bd20.txt
Luke 42186 Posted January 29, 2016 Posted January 29, 2016 Ok but you still have transocding debug logging on C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20151111\ffmpeg.exe -loglevel debug I took this out of the UI because it causes a performance penalty so you'll need to find the server's program data folder /config then delete encoding.xml, then restart
mhuck0625 1 Posted February 1, 2016 Author Posted February 1, 2016 I apologize, Im still in the learning process. I turned something else off instead. However, i found the xml file and deleted it like you requested and it appears to have fixed it! Havent dont a lot of testing yet, but ive tested two videos that were not working beforehand and they are now. Thanks! 1
