Jdiesel 1437 Posted January 27, 2016 Posted January 27, 2016 Even if it is only done through the directshowplayer.xml for now the ability to choose standard or edge filters would be great. 1
Jdiesel 1437 Posted January 28, 2016 Author Posted January 28, 2016 (edited) In the meantime the edge filters can be found here: http://www.mb3admin.com/downloads/thirdparty/mbt_com/edge/ Hopefully the option to enable them internally will be added soon. Edited January 29, 2016 by Jdiesel
