axlns 6 Posted January 10, 2024 Posted January 10, 2024 15 minutes ago, Luke said: Not possible because unlike mkv these are not single files. The players don’t support the structure natively. I see, but isnt it possible to send to TV biggest .m2ts file from BDMV/STREAM folder? basically send the exact file you are using to do re-encoding - but send it to TV as is?
Luke 42276 Posted January 10, 2024 Posted January 10, 2024 31 minutes ago, axlns said: I see, but isnt it possible to send to TV biggest .m2ts file from BDMV/STREAM folder? basically send the exact file you are using to do re-encoding - but send it to TV as is? Then you might end you missing a chunk of the movie.
axlns 6 Posted January 10, 2024 Posted January 10, 2024 I believe software like MPC works this way, they just open biggest m2ts file and that works like in 99.9% cases; usually other files in stream folder are various additional materials/etc and in most cases the biggest file contains entire movie perhaps you can allow this as an "experimental" feature in Server/Transcoding settings? it probably will not hurt because you already saying in client apps that streaming bdmv/iso format is experimental?
axlns 6 Posted July 22, 2024 Posted July 22, 2024 Hi @Luke question, is changed BlurayMounter.dll you posted in this thread now is included by default into new Emby Server installation? or I still need to manually replace it with the file from this thread? thank you!
Luke 42276 Posted July 22, 2024 Posted July 22, 2024 8 hours ago, axlns said: Hi @Luke question, is changed BlurayMounter.dll you posted in this thread now is included by default into new Emby Server installation? or I still need to manually replace it with the file from this thread? thank you! Hi, yes it is included.
