Cerothen 98 Posted January 27, 2016 Posted January 27, 2016 I would like to request that on mobile display of the web client the delay for the multi select be increased by twice or three times as long (or have an option to be disabled) while browsing the library on mobile we often accidentally select a movie and its becoming quite annoying. Thanks for your time. 6
Steind 1 Posted January 27, 2016 Posted January 27, 2016 I second this as well, gets really frustrating when just scrolling and it goes into multi select mode on mobile (android app or web app, same situation)...
Jdiesel 1437 Posted February 5, 2016 Posted February 5, 2016 I find it to be frustrating when scrolling through a list of items due to the frequency that the multi-select option is activated. If you hold your finger for anymore than a split second before swiping it will activate the multi-select option. I propose that the delay time to activate the multi-select be increased to avoid unintentionally bringing up the multi-select option when scrolling through items. 1
Jdiesel 1437 Posted February 5, 2016 Posted February 5, 2016 I would also like to see this looked into.
Jdiesel 1437 Posted February 8, 2016 Posted February 8, 2016 Just tested this on the 2.5.84 beta version. Doubling the delay worked perfectly. Well done.
