Luke 42243 Posted October 15, 2022 Posted October 15, 2022 Hi, it's certainly possible for future updates. Thanks.
kidnappervan 4 Posted November 15, 2022 Posted November 15, 2022 Was thesportsdb.org ever added? I can't find it in Plugins Catalog.
Luke 42243 Posted April 5, 2023 Posted April 5, 2023 4 minutes ago, Jean0987654321 said: Any updates on this? Hi, not yet, sorry.
nobody01 89 Posted May 18, 2023 Posted May 18, 2023 Another for this one please, have around 10 users and would all like this added.
Oracle 86 Posted September 30, 2023 Posted September 30, 2023 7 hours ago, jaketame said: +1 on this too It's unlikely. This thread has been open for like 7 years, with no update except "It's possible for the future." 1
Suliamu 41 Posted November 7, 2023 Posted November 7, 2023 (edited) +1 on this also from me But it is not only about the metadataprovider. There should be generally a new category "Sports" for libraries where you can sort things by event. For example in MMA you have one Event which consists of several parts: Weigh-In, Pre-Prelims, Prelims, Main-Event, Press-Conference afterwards tvdb sorts only the Main-Event (as Movie). But also thesportsdb only sorts the Main-Event. It would be very good if it was possible to make in a Sports-Library somehow a structure which follows the chronological order of the Event inside the Event. For example: MMA (libraryfolder-category: Sports) - MMA Event Number 100 - MMA Event Number 100 - Part01 - 1080p.mkv - MMA Event Number 100 - Part02 - 1080p.mkv - MMA Event Number 100 - Part03 - 1080p.mkv - MMA Event Number 101 - MMA Event Number 101 - Part01 - 1080p.mkv - MMA Event Number 101 - Part02 - 1080p.mkv - MMA Event Number 101 - Part03 - 1080p.mkv - MMA Event Number 101 - Part04 - 1080p.mkv It is basically a structure which has Movies but with Episodes like for Shows/Series. Edited November 7, 2023 by Suliamu
roaku 842 Posted November 7, 2023 Posted November 7, 2023 23 minutes ago, Suliamu said: +1 on this also from me But it is not only about the metadataprovider. There should be generally a new category "Sports" for libraries where you can sort things by event. For example in MMA you have one Event which consists of several parts: Weigh-In, Pre-Prelims, Prelims, Main-Event, Press-Conference afterwards tvdb sorts only the Main-Event (as Movie). But also thesportsdb only sorts the Main-Event. It would be very good if it was possible to make in a Sports-Library somehow a structure which follows the chronological order of the Event inside the Event. For example: MMA (libraryfolder-category: Sports) - MMA Event Number 100 - MMA Event Number 100 - Part01 - 1080p.mkv - MMA Event Number 100 - Part02 - 1080p.mkv - MMA Event Number 100 - Part03 - 1080p.mkv - MMA Event Number 101 - MMA Event Number 101 - Part01 - 1080p.mkv - MMA Event Number 101 - Part02 - 1080p.mkv - MMA Event Number 101 - Part03 - 1080p.mkv - MMA Event Number 101 - Part04 - 1080p.mkv It is basically a structure which has Movies but with Episodes like for Shows/Series. I approximate this by adding the sub-events as extras and using the title sort metadata field to order them. It doesn't allow for fully sorted playback, but it can be used now. 1
Oracle 86 Posted April 4, 2024 Posted April 4, 2024 @LukeAny update on this? What do we need to do to get this implemented? I know a lot of users use Emby to store sports/fight/wrestling media (myself included) and a large amount of the time I have to rely on TMDB or TVDB to scrape this metadata (almost always incorrectly!)
Luke 42243 Posted April 4, 2024 Posted April 4, 2024 It’s certainly possible for future updates. Thanks. 2
TheSportsDBFan 3 Posted August 5, 2024 Posted August 5, 2024 (edited) Hi, Since sports videos are not easy in every system, I have been working on various tools over the last few months. This should help you all too: [Tool] - NFO Zip package generator Forum: https://www.thesportsdb.com/forum_topic.php?t=5973 Direct Link: https://tsdb.sem-one.de/ (will not always stay on this domain!) For Support, use Discort: Discord - TheDataDB And if there is a lot of demand, I will write you a scraper for Emby. I started where I left off 10 years ago, not much has happened since my first scraper in 2014. I hope to have now achieved more change for the next few years. Our Kodi scraper can also download artwork etc: https://www.thesportsdb.com/forum_topic.php?t=5971 Edited August 5, 2024 by TheSportsDBFan 1 2
Oracle 86 Posted October 26, 2024 Posted October 26, 2024 On 8/5/2024 at 1:51 PM, TheSportsDBFan said: Hi, Since sports videos are not easy in every system, I have been working on various tools over the last few months. This should help you all too: [Tool] - NFO Zip package generator Forum: https://www.thesportsdb.com/forum_topic.php?t=5973 Direct Link: https://tsdb.sem-one.de/ (will not always stay on this domain!) For Support, use Discort: Discord - TheDataDB And if there is a lot of demand, I will write you a scraper for Emby. I started where I left off 10 years ago, not much has happened since my first scraper in 2014. I hope to have now achieved more change for the next few years. Our Kodi scraper can also download artwork etc: https://www.thesportsdb.com/forum_topic.php?t=5971 As a contributor to SportsDB, I think this would be beneficial. 1 1
stuffie 1 Posted June 23, 2025 Posted June 23, 2025 At this point i am considering just going to plex as they have a plugin and can do sports
Baenwort 119 Posted July 13, 2025 Posted July 13, 2025 On 8/5/2024 at 12:51 PM, TheSportsDBFan said: Hi, Since sports videos are not easy in every system, I have been working on various tools over the last few months. This should help you all too: [Tool] - NFO Zip package generator Forum: https://www.thesportsdb.com/forum_topic.php?t=5973 Direct Link: https://tsdb.sem-one.de/ (will not always stay on this domain!) For Support, use Discort: Discord - TheDataDB And if there is a lot of demand, I will write you a scraper for Emby. I started where I left off 10 years ago, not much has happened since my first scraper in 2014. I hope to have now achieved more change for the next few years. Our Kodi scraper can also download artwork etc: https://www.thesportsdb.com/forum_topic.php?t=5971 I think Emby does allow plug ins from the community that use API from a metadata site but not scrapping.
Luke 42243 Posted July 15, 2025 Posted July 15, 2025 On 7/13/2025 at 1:13 PM, Baenwort said: I think Emby does allow plug ins from the community that use API from a metadata site but not scrapping. It depends on their terms of use. If they're ok with pulling data from their website, then it's probably fine. The bigger question for this though is whether or not a TV library (and it's naming rules) are adequate for sports content.
kikinjo 294 Posted July 16, 2025 Posted July 16, 2025 Since this was requested 10 years ago (almost), you have next 10 years to find out if TV Library is adequate
ebr 16336 Posted July 16, 2025 Posted July 16, 2025 20 hours ago, Luke said: It depends on their terms of use. If they're ok with pulling data from their website, then it's probably fine. You would need to have written permission from the site to do any such scraping.
Luke 42243 Posted July 16, 2025 Posted July 16, 2025 For those with sports, does your file naming and organization follow tv naming guidelines? Do you currently use the tv content type with it?
crusher11 1143 Posted July 16, 2025 Posted July 16, 2025 3 hours ago, Luke said: For those with sports, does your file naming and organization follow tv naming guidelines? Do you currently use the tv content type with it? Mostly. I use calendar years as seasons, and then YYMMDDGG as the episode number. So s2025e24123103 is the third game played on December 31, 2024. I drop the year digits for sports where the season fits entirely within a single calendar year. For sports with distinct rounds, like the NFL, it's even easier: WWGG as the episode number. So s2024e0104 would be the fourth game of week 1.
Luke 42243 Posted July 16, 2025 Posted July 16, 2025 23 minutes ago, crusher11 said: Mostly. I use calendar years as seasons, and then YYMMDDGG as the episode number. So s2025e24123103 is the third game played on December 31, 2024. I drop the year digits for sports where the season fits entirely within a single calendar year. For sports with distinct rounds, like the NFL, it's even easier: WWGG as the episode number. So s2024e0104 would be the fourth game of week 1. OK that's one way to do it. Another would be to use date based naming without episode numbers. 1
brothom 211 Posted July 17, 2025 Posted July 17, 2025 (edited) A @Lukementioned, sport events should probably be based by dates and probably cups. I've also checked a bunch of European matches, considering this seems to be a US initiative and those are also suprisingly accurate. Looking at thesportsdb.com structure it seems they figured out the most sensible formatting by themselves. An example: Soccer For home matches (https://www.thesportsdb.com/event/2192339-orlando-city-vs-new-york-city-fc) X:/Sports/Soccer/American Major League Soccer/2025/American Major League Soccer - y2025m07d17t001600 - Orlando City - New York City FC For out matches (https://www.thesportsdb.com/event/2192308-charlotte-fc-vs-orlando-city) X:/Sports/Soccer/American Major League Soccess/2025/American Major League Soccer - y2025m07d05t231500 - Charlotte FC - Orlando City Ice Hockey The above also seems to apply to other sport: https://www.thesportsdb.com/event/2250315-eisbären-berlin-vs-kolner X:/Sports/Ice Hockey/German DEL/2024-2025/German DEL - y2025m04d25t173000 Eisbaren Berlin - Kolner Lacrosse https://www.thesportsdb.com/event/2257685-buffalo-bandits-vs-saskatchewan-rush X:/Sports/Lacrosse/National Lacrosse League/2024-2025/National Lacrosse League - y2025m05d16t232300 - Buffalo Bandits - Saskatchewan Rush These are of course fully qualified to prevent any same-day matches and could be abbreviated to: X:/Sports/WhichSport/WhichLeague/WhichSeason/WhichLeague - y{year}m{month}d{date}t{time?} - Home vs Out Or maybe even just: X:/Sports/Lacrosse/National Lacrosse League - y2025m05d16 The filename itself provides enough information for the item to be found via the API (with date or even exact time matches, there's only 1 match that day). I couldn't find out if abbreviations works correctly via the API but if they do formatting could be cut down even further, but won't make the contents any more clear and only encourage users to "go wild": X:/Sports/NLL/NLL - y2025m05 Edited July 17, 2025 by brothom 1 1
