MSattler 390 Posted January 25, 2016 Posted January 25, 2016 Fire TV Stick with Emby App Server Version 3.0.5845.0 With some movies playback sounds as if only the rear audio of a 5.1 track is being played, when the Fire TV stick is setup for 2 channel Stereo. Movie Info: Video CodecH264ProfileHighLevel41Resolution1920x1080Aspect ratio16:9AnamorphicNoInterlacedNoFramerate23.97602Bitrate36182 kbpsBit depth8 bitPixel formatyuv420pRef frames4CABACYes Audio LanguageengCodecDCAProfileDTS-HD MALayout5.1Channels6 chSample rate48000 khzDefaultYes Audio LanguageengCodecDCAProfileDTSLayout5.1Channels6 chBitrate1500 kbpsSample rate48000 khzDefaultNo Audio LanguagedeuCodecDCAProfileDTSLayout5.1Channels6 chBitrate750 kbpsSample rate48000 khzDefaultNo Log example: http://pastebin.ca/3349465 Thanks, Marcus
ebr 16336 Posted January 25, 2016 Posted January 25, 2016 In the app settings, change the audio mode to "Compatible".
MSattler 390 Posted January 25, 2016 Author Posted January 25, 2016 In the app settings, change the audio mode to "Compatible". My end user tried that, but no change. Does it require a app restart/stick reboot for it to take effect?
ebr 16336 Posted January 25, 2016 Posted January 25, 2016 Oh shoot. This item would be transcoding so that setting would have no effect. Has to be some sort of error on how it is being transcoded on the server. What happens if you make the second audio track the default?
MSattler 390 Posted January 25, 2016 Author Posted January 25, 2016 Oh shoot. This item would be transcoding so that setting would have no effect. Has to be some sort of error on how it is being transcoded on the server. What happens if you make the second audio track the default? I've asked my user to test. Here is the thing though, for FireTV Sticks where only 2 channel is put out, should it be converting it to 6 channel? C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20151111\ffmpeg.exe -ss 00:05:45.000 -i file:"\\tower\bluray\Ex Machina\Ex_Machina.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -b:v 21325998 -maxrate 21325998 -bufsize 42651996 -vsync vfr -profile:v high -level 40 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,4096)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -sc_threshold 0-output_ts_offset 00:05:45.000 -codec:a:0 aac -strict experimental -ac 6 -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 115 -hls_list_size 0 -y "C:\Users\Administrator\AppData\Roaming\Emby-Server\transcoding-temp\c4d6979da85fc24d82dcb878f9c6466d.m3u8"
ebr 16336 Posted January 25, 2016 Posted January 25, 2016 The stick actually should be able to put out 5.1 if it is connected to the proper equipment. I think that is actually what is happening to you now. it is outputting 5.1 and your TV is only playing the L/R channels. I think most TVs will automatically downmix in that situation. You might have them check to see if there is a setting on the TV input for audio stereo vs. 5.1...
