Turn Off Navigation Sounds?
Go to solution Solved by Dazik,
Hi Luke,
I had seen that. And sound effects was set to "none" but I was still getting the ping sound while navigating so I assumed that wasn't it.
However, I just changed it from "none" to "default sound effects" and then back to "none" again. Now I am not getting sounds while navigating. So it appears almost as if the menu setting was correct but the underlying setting had not been initialized. It's working now so I can't test it again. But that seems to be what was happening.  Odd.
As always, thanks for your help.
So you have it set to none now?
Yes. And I am not getting sounds now. That is the behavior I would expect.
I'm 95-ish% sure it was set to none while I was still getting sounds and it stopped once I changed it to something else and then back again. This was literally the first time I ever opened theater mode. So I was thinking maybe it showed that as a default for some reason while no value was ever actually set.
  • Thanks 1
