pavipollo 0 Posted January 22, 2016 Posted January 22, 2016 Hi everyone, first of all greetings to the community, from a new member (me)! Secondly I have, of course, a problem (two actually)... First problem: I just installed the server (v. 3.05786.0) on my MacMini running Yosemite (10.10.5). Installation is ok and I can access locally the web interface on the IP of the machine (192.168.22.69:8096). However I cannot access the server remotely, neither via the static IP nor via dyndns. In both cases the error is that the page cannot be found. I obviously opened (forwarded) TCP port 8096 in my router (Cisco EPC3925) but if I check with Open Port Check Tool I get the message "Error: I could not see your service on [ip address] on port (8096). Reason: connection refused". In netstat the port appears to be ok (if I understand correctly): tcp4 0 0 192.168.22.69.8096 192.168.22.69.59633 ESTABLISHED tcp4 0 0 192.168.22.69.59633 192.168.22.69.8096 ESTABLISHED The situation does not change if I change port, btw. Second problem: To see if the situation changes I installed the server on my other MacMini running Mountain Lion, which is placed in another location (with another IP address). Installation is ok and I can access locally the web interface on the IP of the machine (this time 192.168.22.69:8096). However even in this case I cannot even forward the port in my router (FritzBox 7360)! The Fritz refuses with the error message that the requested forwarding is in contrast with an existing internal rule... Any idea what kind of mess I made?
Luke 42237 Posted January 22, 2016 Posted January 22, 2016 you might need to setup port forwarding from your router to your machine. I'd take a look at our wiki on Connectivity which goes over that as well as other troubleshooting steps you can try: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Let us know if you're still having issues. Thanks.
pavipollo 0 Posted January 22, 2016 Author Posted January 22, 2016 Thanks but as I already wrote "I obviously opened (forwarded) TCP port 8096 in my router (Cisco EPC3925)" and "I cannot even forward the port in my router (FritzBox 7360)! The Fritz refuses with the error message that the requested forwarding is in contrast with an existing internal rule..." I'm certainly a noob, but not that noob....
Luke 42237 Posted January 22, 2016 Posted January 22, 2016 That rule is probably the one we attempted to setup. What you could try is deleting that rule and then creating a new one, making sure its' on TCP
pavipollo 0 Posted January 22, 2016 Author Posted January 22, 2016 That's the odd part, there's no other rule! I have no other forwarding to port 8096... Moreover it says the same whatever other port number I choose.
