kelly.mumm 0 Posted January 22, 2016 Posted January 22, 2016 Hello I have successfully gotten streaming to work in a browser and on a Roku but when I try it on the Fire TV it says it is playing the channel but just spins. On the server interface says the device is streaming and trans-coding but I never see the FFMPEG process start. I am remote to the server if that makes any difference. The Roku is hooked up to the same TV and works fine.
kelly.mumm 0 Posted January 22, 2016 Author Posted January 22, 2016 Hello I have successfully gotten streaming to work in a browser and on a Roku but when I try it on the Fire TV it says it is playing the channel but just spins. On the server interface says the device is streaming and trans-coding but I never see the FFMPEG process start. I am remote to the server if that makes any difference. The Roku is hooked up to the same TV and works fine. NM I figured it out. Had to turn off the direct stream live tv option. Did see it the first 10 times I went to settings
ebr 16336 Posted January 22, 2016 Posted January 22, 2016 Correct. If you are not on the same network as the tv tuner, then direct-streaming won't work. I'd like to make this more automatic but also fear it could mis-diagnose some situations, so the manual setting is there.
DannyN 1 Posted February 5, 2016 Posted February 5, 2016 Where is the "direct stream" setting please? Thanks Sent from my iPhone using Tapatalk
