Luke 42243 Posted October 24, 2016 Posted October 24, 2016 Okay, I had NES all finished with artwork and metadata. It took me several hours to complete it manually since the scraping from TGDB doesn't work very well and accurate. All of that has disappeared after the last server update. Not sure how. Just very disappointed how it got all lost. Is there away that these artwork and metadata to be saved as nfo files that this could not happen again? Also, any chance someone able to see the issue why the external players not working on the different platforms other than just NES? Thank you. Can you help diagnose the issue? Find the ET install folder, then locate the main.js file by searching within. Then find a line that is something like // mainWindow.openDevTools(); Remove the two // from the beginning, save and start the app. Now it will run with a debugger console embedded. Try to play and see if it produces any errors. Thanks !
cash84 4 Posted October 27, 2016 Posted October 27, 2016 Can you help diagnose the issue? Find the ET install folder, then locate the main.js file by searching within. Then find a line that is something like // mainWindow.openDevTools(); Remove the two // from the beginning, save and start the app. Now it will run with a debugger console embedded. Try to play and see if it produces any errors. Thanks ! Not a problem. Okay, I looked into it and not really good at trying to find the cause would be but here's a start. When I play under NES platform, it will do a shellstart command electronapphost://shellstart?path Under SNES platform, it will not show a shellstart command. If this not enough, could you point me into the right spot. I know in the Audit, it shows quite a lot of errors if that helps with what you need. Thanks
Luke 42243 Posted October 27, 2016 Posted October 27, 2016 Can you grab a screenshot of the errors? thanks.
cash84 4 Posted October 27, 2016 Posted October 27, 2016 This is part of the list. If you want all of it, I can take more screenshots.
Luke 42243 Posted October 27, 2016 Posted October 27, 2016 What about the console tab? that is where the actual application problems would be.
cash84 4 Posted October 27, 2016 Posted October 27, 2016 I'm getting a hang of this now I found the error it's showing. hope this helps
Luke 42243 Posted October 28, 2016 Posted October 28, 2016 do you have game.xml metadata files for those games? If so, do they contain a GameSystem value?
cash84 4 Posted October 28, 2016 Posted October 28, 2016 the only metadata that I would have would be coming from default. So I didn't add anything like that.
Luke 42243 Posted October 28, 2016 Posted October 28, 2016 Ok but i'm still asking the same question.
cash84 4 Posted October 28, 2016 Posted October 28, 2016 Okay I'm trying to find it and not having any luck. Would you know what folder structure it would be in if I had one?
Luke 42243 Posted October 28, 2016 Posted October 28, 2016 it would be in the same folder as your game. it's not required to work i was just curious.
cash84 4 Posted October 28, 2016 Posted October 28, 2016 Ahh okay, Yeah there's nothing there in any of the games
SirMedia 0 Posted December 16, 2016 Posted December 16, 2016 I have a probleme, i configured my emby server plugin Gamebrowser, with the new interface, thanks for that, i modified my gameBrowser.xml . I created directory for each console in my library (this ok for that) But when i loaded my emby for WMC, my gamebrowser.xml change for gamebrowser.xml.old and a new file gamebrowser.xml is created, he d'ont take my configuration my gamebrowser.xml <?xml version="1.0" encoding="utf-8"?><GameBrowserSettings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <GameSystems> <anyType xsi:type="GameSystem"> <Name>Game Cube</Name> <Executable>G:\Program Files\Dolphin\Dolphin.exe</Executable> <Switches>"--exec={rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Nintendo</Name> <Executable>G:\Emulateurs\Nintendo\jnes_1_1_1\Jnes.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Nintendo 64</Name> <Executable>G:\Program Files (x86)\Project64 1.6\Project64.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Playstation</Name> <Executable>G:\Emulateurs\Playstation\ePSXe205\ePSXe.exe</Executable> <Switches>-nogui -loadbin "{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Super Nintendo</Name> <Executable>G:\Emulateurs\Super Nintendo\snes9x.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Nintendo DS</Name> <Executable>G:\Emulateurs\Nintendo DS\DeSmuME_0.9.11_x64.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Game Boy Advance</Name> <Executable>G:\Emulateurs\Game Boy\VisualBoyAdvance.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Sega Genesis</Name> <Executable>G:\Emulateurs\Sega Genesis\Gens32 Surreal.exe</Executable> <Switches>-fullscreen "{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Game Boy</Name> <Executable>G:\Emulateurs\Game Boy\VisualBoyAdvance.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Game Boy Color</Name> <Executable>G:\Emulateurs\Game Boy\VisualBoyAdvance.exe</Executable> <Switches>"{rom}"</Switches> </anyType> <anyType xsi:type="GameSystem"> <Name>Sega Saturne</Name> <Executable>G:\Emulateurs\Sega Saturne\yabause.exe</Executable> <Switches>"{rom}"</Switches> </anyType> </GameSystems> <DosGames /> <WinGames> </anyType> <anyType xsi:type="GameSystem"> <Name>Age of Empires</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Age of Empires\Age of Empires.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Age of Empires Expansion</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Age of Empires Expansion\Age of Empires Expansion.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Age of Empires II HD</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Age of Empires II HD\Age of Empires II HD.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Age of Empires III - Warchiefs</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Age of Empires III - Warchiefs\Age of Empires III - Warchiefs.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Age of Empires III - Asian dynasties</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Age of Empires III - Asian dynasties\Age of Empires III - Asian dynasties.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Age of Mythology Extended Edition</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Age of Mythology Extended Edition\Age of Mythology Extended Edition.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Diablo II - Lord of Destruction</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Diablo II - Lord of Destruction\Diablo II - Lord of Destruction.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Heroes of Might and Magic 3 HD</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Heroes of Might and Magic 3 HD\Heroes of Might and Magic 3 HD.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Heroes of Might and Magic V</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Heroes of Might and Magic V\Heroes of Might and Magic V.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Heroes of Might and Magic IV Winds of War</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Heroes of Might and Magic IV Winds of War\Heroes of Might and Magic IV Winds of War.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Heroes of Might and Magic V - Hammers of Fate</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Heroes of Might and Magic V - Hammers of Fate\Heroes of Might and Magic V - Hammers of Fate.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Heroes of Might and Magic V - Tribes of the East</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Heroes of Might and Magic V - Tribes of the East\Heroes of Might and Magic V - Tribes of the East.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Magic Duels</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Magic Duels\Magic Duels.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Heroes VI - Might & Magic</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Heroes VI - Might & Magic\Heroes VI - Might & Magic.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Might and Magic Heroes VII</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Might and Magic Heroes VII\Might and Magic Heroes VII.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>StarCraft - Brood War</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\StarCraft - Brood War\StarCraft - Brood War.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Starcraft II</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Starcraft II\Starcraft II.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Warcraft II</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Warcraft II\Warcraft II.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Warcraft III</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Warcraft III\Warcraft III.url</Executable> <Switches /> </anyType> <anyType xsi:type="GameSystem"> <Name>Warcraft III - The Frozen Throne</Name> <Executable>C:\Users\SirMedia\Desktop\Jeux\Warcraft III - The Frozen Throne\Warcraft III - The Frozen Throne.url</Executable> <Switches /> </anyType> <WinGames /> <EnableQuitKey>false</EnableQuitKey> <SelectedQuitKey>0</SelectedQuitKey></GameBrowserSettings> My games d'ont start because the gamebrowser.xml changed for that <?xml version="1.0" encoding="utf-8"?><GameBrowserSettings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <EnableQuitKey>false</EnableQuitKey> <SelectedQuitKey>0</SelectedQuitKey></GameBrowserSettings> Please help me
Luke 42243 Posted December 16, 2016 Posted December 16, 2016 If it's getting replaced automatically, it's probably due to being invalid xml.
frankmomma 2 Posted December 18, 2016 Posted December 18, 2016 (edited) @@cash84 @@Luke sorry i had a bunch of work since my last question and haven't been able to mess around with getting my games working. I am still having the loading wheel issue with all of my RomsIf you are still willing to help me out, focusing on the genesis emulator would be helpful. I feel like once i get one of them working i will have more of an understanding and be able to get the others working as well. I am using Fusion364 emulator and this is what my external player setting looks like in Emby Theater 2.5.32Thank you Edited December 18, 2016 by frankmomma
Luke 42243 Posted December 20, 2016 Posted December 20, 2016 Have you researched line arguments required by fusion?
frankmomma 2 Posted December 20, 2016 Posted December 20, 2016 I have been looking for a while now and pretty much everything i am finding looks like this: -gen -auto -fullscreen Which still doesnt work.
