OpenSourceUser 6 Posted January 18, 2016 Posted January 18, 2016 Is anyone working on a plugin for Rocktstor? (NAS OS based on CentOS with Btrfs) See: http://rockstor.com/
Luke 42243 Posted January 18, 2016 Posted January 18, 2016 Hi, welcome. At the moment, no. Could the normal CentOS package be used for it?
hurricanehrndz 149 Posted January 18, 2016 Posted January 18, 2016 We will have one soon. Look for something later today on the main page. 1
hurricanehrndz 149 Posted January 18, 2016 Posted January 18, 2016 Please see the wiki: https://github.com/MediaBrowser/Wiki/wiki/Docker-Getting-Started
OpenSourceUser 6 Posted January 19, 2016 Author Posted January 19, 2016 Didn't expact such a fast response Thank you very much. I will send a message to the rocktor team to make them advertise that Emby is ready to be run on their systems 1
OpenSourceUser 6 Posted April 11, 2016 Author Posted April 11, 2016 Sorry for double posting Is there a possibility to update the software via GUI? I even tried to reinstall, but ended up with version 3.0.5871.0 again. Not quite sure whether this might be a problem that needs to be fixed on the rockstor side. Thanks for any information on this.
hurricanehrndz 149 Posted April 13, 2016 Posted April 13, 2016 Sorry for double posting Is there a possibility to update the software via GUI? I even tried to reinstall, but ended up with version 3.0.5871.0 again. Not quite sure whether this might be a problem that needs to be fixed on the rockstor side. Thanks for any information on this. Not from the gui, nope sorry.
hurricanehrndz 149 Posted April 13, 2016 Posted April 13, 2016 You can from the command line, the wiki explains how to even do a cron job so that it automatically updates on its own
