vdatanet 1619 Posted January 22, 2016 Author Posted January 22, 2016 (edited) Decoder Panasonic sa-ht07 5.1 AAC input gets a stero PCM output. Thanks Edited January 22, 2016 by vdatanet 1
vdatanet 1619 Posted January 22, 2016 Author Posted January 22, 2016 (edited) What about not transcoding audio if supported? For example, when bandwidth is limited, plex transcodes video but audio not. An option "Don't transcode audio if supported" would be nice. Edited January 22, 2016 by vdatanet
chessdragon136 677 Posted January 22, 2016 Posted January 22, 2016 What about not transcoding audio if supported? For example, when bandwidth is limited, plex transcodes video but audio not. An option "Don't transcode audio if supported" would be nice. Generally this isn't done as it can cause sync issues,
cmcg 876 Posted January 22, 2016 Posted January 22, 2016 (edited) Also how would you know "if supported"? Quite tricky. Edited January 23, 2016 by cmcg
CBers 7554 Posted January 23, 2016 Posted January 23, 2016 Emby is still transcoding my DTS audio to AC3 in the Win10 app, and thought it was mentioned the Roku app also transcodes to AC3 I always thought AC3 was transcoded to AAC.
FrostByte 5453 Posted January 23, 2016 Posted January 23, 2016 (edited) Yes, the app converts everything to AAC expect in the case if original input is AAC you can tell it to convert it to AC3 Edited January 23, 2016 by FrostByte
cmcg 876 Posted February 10, 2016 Posted February 10, 2016 The fix for this issue is in the current beta 2.1.0d. Could you see if this fixes the issue please @@vdatanet 1
vdatanet 1619 Posted February 10, 2016 Author Posted February 10, 2016 Perfect! Now AC3 is transcoded to AC3 instead of AAC Thanks! 1
CBers 7554 Posted February 10, 2016 Posted February 10, 2016 Perfect! Now AC3 is transcoded to AC3 instead of AAC Thanks! Under what circumstances ?? My Samsung TV is capable of direct playing AC3, so I'm a little confused.
vdatanet 1619 Posted February 10, 2016 Author Posted February 10, 2016 (edited) Under what circumstances ?? My Samsung TV is capable of direct playing AC3, so I'm a little confused. Hi, My bandwidth is limited to 10 Mbps, so when I access to remote server, I need to transcode the movie to lower bitrate. In previous versions, AC3 audio was transcoded to AAC, now AC3 audio is transcoded to AC3. My receiver can't decode multichannel AAC, only AC3. So this change is very good for me. Thanks Edited February 10, 2016 by vdatanet 1
FrostByte 5453 Posted February 10, 2016 Posted February 10, 2016 (edited) @CBers To put it simply the change just makes it so your default transcoding codec can now be AC3 instead of AAC if you have both the settings below set to True. As it was before the only time the code behind the second setting executed was if the original file was AAC. In all other cases the app used to transcode to AAC and ignore that second setting This may be good news for you if you still have that sound bar which doesn't play DTS. You can now transcode DTS to AC3 if you wish Your AC3 files should be fine though, mine play without transcoding Enable Dolby Digital Playback: true Enable AAC Transcoding to Dolby: true Edited February 10, 2016 by FrostByte 1
CBers 7554 Posted February 10, 2016 Posted February 10, 2016 Thanks Frosty I don't want any transcoding. Still don't know why the TV doesn't switch to Dolby when it receives AAC audio like it does for AC3.
FrostByte 5453 Posted February 10, 2016 Posted February 10, 2016 (edited) I don't want any transcoding. Agree, I don't have anything that needs transcoding with my receiver, but have mine set to True now because I prefer AC3 over AAC if it ever does have to transcode and I don't encode anything with AAC either so I don't have to worry about that. Would have preferred cmcg and chessdragon136 left that option the way it was and just added another option like "Default transcoding codec" with options "AAC" or "Dolby". That way it would have solved both vdatanet's problem and allowed others who want our default transcoding codec to be Dolby without transcoding AAC to Dolby also if not needed. Edited February 10, 2016 by FrostByte 1
