Killervette 5 Posted December 14, 2013 Posted December 14, 2013 When I have tv or video running and go to chocolate, it won't show backdrops. Is there a setting I am missing?
Cheesegeezer 3106 Posted December 14, 2013 Posted December 14, 2013 When I have tv or video running and go to chocolate, it won't show backdrops. Is there a setting I am missing? I'm not sure what you are after. Do you mean if you are watching a movie in MBC or navigate to chocolate from LiveTV, the the TV or movie is playing. If that's the case look at Chocolate views in the config and the term your are looking for is NPV(which means Now Playing Video). There is an option for you to have it off or use a small NPV view instead of full screen. If i'm incorrect in my assumption, please provide details and screenshots of what you are talking about. Thanks Cheese
ebr 16342 Posted December 14, 2013 Posted December 14, 2013 Cheeze is right. Deselect "Show Video Backdrop" and select "Show small NPV".
Killervette 5 Posted December 14, 2013 Author Posted December 14, 2013 I have those options checked. When watching live tv, I get the small preview window but no backdrop. I will try and get some screenshots tomorrow. And the backdrops do load fine when no video is playing.
ebr 16342 Posted December 14, 2013 Posted December 14, 2013 If you have the small NPV enabled, you need to Deselect the show video backdrops option. I don't know why those are two separate options. They should be a switch of either or. It makes no sense to have them both turned on.
Killervette 5 Posted December 14, 2013 Author Posted December 14, 2013 If you have the small NPV enabled, you need to Deselect the show video backdrops option. I don't know why those are two separate options. They should be a switch of either or. It makes no sense to have them both turned on. I think I have, but I will check again.
