neik 874 Posted November 11, 2021 Posted November 11, 2021 14 hours ago, Dx111111 said: Other subs that people manually add (.srt) are not always accurate This are the ones I am talking about as afaik only srt subs can be delayed, graphical subs (sub, pgs) cannot. 14 hours ago, Dx111111 said: but how would you sync the adjustments to other users if they don't have the exact same .srt file? Imagine: I have family living in Portugal and I want to give them access to my server. All my files though only have German + English, everything else I through away when ripping the disc - reripping is not an option as it would be way to time intensive. Now I grab a Portuguese srt from e.g. Opensubtitles but it is out of sync let's say 600ms. What I am trying to say is: Whenever the first user notices the delay and fixes it for himself (by setting +/- 600ms) this information should be stored globally for all users as all other users will run into the same delay issue if they use that sub. Somehow clear now?
ebr 16339 Posted November 11, 2021 Posted November 11, 2021 20 hours ago, Dx111111 said: but how would you sync the adjustments to other users if they don't have the exact same .srt file? Hi. Users don't have separate subtitle files. Everyone is looking at the same media. Saving the offset globally makes sense.
Dx111111 1 Posted November 11, 2021 Posted November 11, 2021 38 minutes ago, ebr said: Hi. Users don't have separate subtitle files. Everyone is looking at the same media. Saving the offset globally makes sense. No, not at all? Example: I download a .srt file somewhere rename it so it's the exact same name as the movie, the sub a bit out of sync, so I sync it with the movie. Or I download a different .srt file that has a different timetable. Everyone else with that movie and an srt file should then receive my sync? Horrible plan, since that movie has like 20 different .srt files available for the same language subtitle. It would trow all those other people out of sync.
Dx111111 1 Posted November 11, 2021 Posted November 11, 2021 6 hours ago, neik said: Somehow clear now Sorry, not at all. A .srt file has only the filename as an identifier. And usually you change the filename to match the movie. If I match my .srt file to my movie, and you match your (different) srt file to the same movie, and we sync those, one of us is gonna be out of sync.
neik 874 Posted November 11, 2021 Posted November 11, 2021 I think there is a misunderstanding: Global does not mean the delay will be shared between Emby servers (e.g. yours and mine) but the delay would be stored within my server/database only.
Dx111111 1 Posted November 11, 2021 Posted November 11, 2021 31 minutes ago, neik said: I think there is a misunderstanding: Global does not mean the delay will be shared between Emby servers (e.g. yours and mine) but the delay would be stored within my server/database only. Ohhhh yes since global was said, I thought you meant between all Emby users. Yes, on the same server, with multiple users, it would make sense.
neik 874 Posted November 11, 2021 Posted November 11, 2021 19 minutes ago, Dx111111 said: Yes, on the same server, with multiple users, it would make sense. Now we are on the same page.
MikeyMan 8 Posted May 3, 2022 Posted May 3, 2022 Should the offset be available on the Chromecast with Google TV app? Can't seem to find it.
Luke 42246 Posted May 3, 2022 Posted May 3, 2022 2 hours ago, MikeyMan said: Should the offset be available on the Chromecast with Google TV app? Can't seem to find it. Hi, what version of the Emby app do you have?
MikeyMan 8 Posted May 3, 2022 Posted May 3, 2022 I assume the latest stable. Have to check the numbering when I'm home
Malmgren 17 Posted May 3, 2022 Posted May 3, 2022 ...and the LG app also still miss it. It's the one and only feature I've been waiting for since I started using Emby...
MikeyMan 8 Posted May 3, 2022 Posted May 3, 2022 11 minutes ago, Malmgren said: ...and the LG app also still miss it. It's the one and only feature I've been waiting for since I started using Emby... The LG app on my c9 does have the option. That's why I was looking for it.
Luke 42246 Posted May 3, 2022 Posted May 3, 2022 22 minutes ago, Malmgren said: ...and the LG app also still miss it. It's the one and only feature I've been waiting for since I started using Emby... It's definitely in the latest update to the Emby LG app. 1
Malmgren 17 Posted May 4, 2022 Posted May 4, 2022 On 5/3/2022 at 8:14 PM, Luke said: It's definitely in the latest update to the Emby LG app. Is it hidden somewhere else than in the other apps? I've been looking and I can't seem to find it. I'm on version 1.0.35.
Luke 42246 Posted May 4, 2022 Posted May 4, 2022 10 minutes ago, Malmgren said: Is it hidden somewhere else than in the other apps? I've been looking and I can't seem to find it. I'm on version 1.0.35. Remember that it's only used with external text subtitles, so that might be the reason you're not seeing it.
ebr 16339 Posted May 4, 2022 Posted May 4, 2022 1 hour ago, MikeyMan said: The version on Chromecast seems to be 2.0.70g. The option is in the subtitle menu during playback but, again, it only applies to external text subtitles.
MikeyMan 8 Posted May 4, 2022 Posted May 4, 2022 35 minutes ago, ebr said: The option is in the subtitle menu during playback but, again, it only applies to external text subtitles. On the LG it's not in the subtitle menu but in the general settings under the cog icon. I'm checking the exact same files with the exact same server with the exact same subtitles. It's not there. 1
ebr 16339 Posted May 4, 2022 Posted May 4, 2022 Can we please look at a specific example? Please play that item for a few seconds and then follow the instructions to send a log from the app?
MikeyMan 8 Posted May 5, 2022 Posted May 5, 2022 Just sent the log. Didnt see any identifier in can share. Did you get it?
ebr 16339 Posted May 5, 2022 Posted May 5, 2022 The item you are playing appears to have a single internal subtitle track. The offset only works with external sub tracks. 05-05 10:08:06.788 3164 3164 I System.out: *** External sub streams: 0 ... 05-05 10:08:07.407 3164 3164 D EventLogger: TextRenderer [ 05-05 10:08:07.407 3164 3164 D EventLogger: Group:0, adaptive_supported=N/A [ 05-05 10:08:07.407 3164 3164 D EventLogger: [ ] Track:0, id=3, mimeType=application/x-subrip, language=en, label=English, supported=YES 05-05 10:08:07.407 3164 3164 D EventLogger: ] 05-05 10:08:07.407 3164 3164 D EventLogger: ]
MikeyMan 8 Posted May 5, 2022 Posted May 5, 2022 Thats weird, on my LG it is working without any issue.
FrostByte 5454 Posted May 5, 2022 Posted May 5, 2022 I believe the Samsung and LG apps have to extract the internal subtitles first and overlay the two streams. Android apps don't need that option
MikeyMan 8 Posted May 5, 2022 Posted May 5, 2022 (edited) 14 minutes ago, FrostByte said: I believe the Samsung and LG apps have to extract the internal subtitles first and overlay the two streams. Android apps don't need that option If that’s the case, i’d say at least make the experience consistent. There is quite some difference between the various apps/solutions at the moment. Does this also imply that if there’s an internal sub, it wont search for others? Edited May 5, 2022 by MikeyMan
ebr 16339 Posted May 5, 2022 Posted May 5, 2022 The different players on different platforms have different capabilities but it would be very odd for an internal subtitle track to need timing adjustments...
