edd-- 2 Posted December 7, 2020 Posted December 7, 2020 +1 on the android implementation, this would make the subtitle experience perfect ! Thanks for all your great work !
miniliQuid 95 Posted December 9, 2020 Posted December 9, 2020 On 12/7/2020 at 10:03 PM, edd-- said: +1 on the android implementation, this would make the subtitle experience perfect ! Thanks for all your great work ! Android mobile has it already. Not sure about android TV though.
ebr 16339 Posted December 22, 2020 Posted December 22, 2020 The latest beta of the Android TV app now has subtitle offset.
coldviber 0 Posted December 23, 2020 Posted December 23, 2020 (edited) On 12/22/2020 at 8:48 PM, ebr said: The latest beta of the Android TV app now has subtitle offset. In my app the option won't show. I already removed and install the app again. In the mobile is working fine. Yes I'm using the beta version for android tv Edited December 23, 2020 by coldviber
seanbuff 1356 Posted December 23, 2020 Posted December 23, 2020 6 minutes ago, coldviber said: In my app the option won't show. I already removed and install the app again. In the mobile is working fine. Yes I'm using the beta version for android tv Which version of the ATV beta app are you running? You might need to side-load the latest version as there is a delay on releases from the Play Store.
CBers 7556 Posted December 23, 2020 Posted December 23, 2020 11 minutes ago, coldviber said: In my app the option won't show. I already removed and install the app again. In the mobile is working fine. Yes I'm using the beta version for android tv Only works with "external subs only". See Release Notes for v1.8.60 here.
tchirou 23 Posted December 23, 2020 Posted December 23, 2020 Do you have a rough eta of when it will be available in the stable channel ? thanks a lot
ebr 16339 Posted December 24, 2020 Posted December 24, 2020 16 hours ago, tchirou said: Do you have a rough eta of when it will be available in the stable channel ? thanks a lot I cannot promise anything but we typically target app releases at least every three months. We are a few weeks into the current beta cycle now.
emoby0 5 Posted January 7, 2021 Posted January 7, 2021 Hi there - I'm wondering if the Roku client will ever be updated with this feature? My understanding is that neither the plex or emby clients can support this (possibly due to roku?) 1
Luke 42246 Posted January 7, 2021 Posted January 7, 2021 3 minutes ago, emoby0 said: Hi there - I'm wondering if the Roku client will ever be updated with this feature? My understanding is that neither the plex or emby clients can support this (possibly due to roku?) Hi, we're looking into it but yes you are correct that the Roku video player developer api is not as robust as other platforms, so we're going to be limited by that. 1
emoby0 5 Posted January 7, 2021 Posted January 7, 2021 1 hour ago, Luke said: Hi, we're looking into it but yes you are correct that the Roku video player developer api is not as robust as other platforms, so we're going to be limited by that. Thanks Luke - appreciate the response. Now to decide if I should get a TV with a different platform I have a standalone Android TV box, so I'll try out that client as well. I have this impression that the app running on the TV natively has slightly better image quality
umomany 0 Posted January 11, 2021 Posted January 11, 2021 Is this feature going reach emby TV any time soon ?
Luke 42246 Posted January 11, 2021 Posted January 11, 2021 4 minutes ago, umomany said: Is this feature going reach emby TV any time soon ? Hi there, which Emby app are you referring to?
umomany 0 Posted January 11, 2021 Posted January 11, 2021 19 minutes ago, Luke said: Hi there, which Emby app are you referring to? the one on LG smart TVs, current version is 1.0.24 updated on 21st Feb 2020
Luke 42246 Posted January 11, 2021 Posted January 11, 2021 25 minutes ago, umomany said: the one on LG smart TVs, current version is 1.0.24 updated on 21st Feb 2020 It will be in the next update to the app. Thanks.
F1nchy 29 Posted February 23, 2021 Posted February 23, 2021 (edited) Is there any update on subtitles offset for Android TV devices? We have subs on most things and I have to keep using Plex or Kodi when the subs are out and I can't get better ones. Plex has had it for a while and does it ok (clumsy, a bit hit and miss), Kodi has had it for ages and nailed it pretty quickly. It's one of the few things Emby falls short on for us. We use Emby on a Shield TV, a Humax Aura and a Sony Bravia, all Android TV. Thanks Edited February 23, 2021 by F1nchy
GrimReaper 4905 Posted February 23, 2021 Posted February 23, 2021 (edited) 3 hours ago, F1nchy said: Is there any update on subtitles offset for Android TV devices? We have subs on most things and I have to keep using Plex or Kodi when the subs are out and I can't get better ones. Plex has had it for a while and does it ok (clumsy, a bit hit and miss), Kodi has had it for ages and nailed it pretty quickly. It's one of the few things Emby falls short on for us. We use Emby on a Shield TV, a Humax Aura and a Sony Bravia, all Android TV. Thanks It has been implemented for some time on beta channel, I think since .60, more or less, if it is a necessity, you might check latest beta .75. (Edit: .76 is out in the meantime) Edited February 23, 2021 by GrimReaper76 Append
F1nchy 29 Posted February 23, 2021 Posted February 23, 2021 Do I have to install beta manually? It says I am a beta tester in the Play store?
GrimReaper 4905 Posted February 23, 2021 Posted February 23, 2021 2 hours ago, F1nchy said: Do I have to install beta manually? It says I am a beta tester in the Play store? Then you should've already have it installed? On cog wheel press, what does it say what app version you have in the bottom right?
F1nchy 29 Posted February 23, 2021 Posted February 23, 2021 On the Aura it's 1.8.54g (server 4.5.4.0)
GrimReaper 4905 Posted February 23, 2021 Posted February 23, 2021 2 hours ago, F1nchy said: On the Aura it's 1.8.54g (server 4.5.4.0) That's latest stable. I'm unfamiliar with that device, but I'd guess it didn't propagate there. How do you install apps there? Through Play Store or dedicated App store? Are you logged as same Google user?
F1nchy 29 Posted February 23, 2021 Posted February 23, 2021 The Aura uses the Google Play store, it's running normal Android TV and gets the apps through the play store. I've also just looked at my Shield TV and that is running exactly the same version, 1.8.54g, and no subtitles offset on that either. I'll check the Bravia but I'm sure that's the same.
GrimReaper 4905 Posted February 23, 2021 Posted February 23, 2021 (edited) 3 hours ago, F1nchy said: The Aura uses the Google Play store, it's running normal Android TV and gets the apps through the play store. I've also just looked at my Shield TV and that is running exactly the same version, 1.8.54g, and no subtitles offset on that either. I'll check the Bravia but I'm sure that's the same. Then I suppose you could sideload beta app, and open a ticket in the Android section of why you ain't getting beta versions downloaded. Edit: And no, .54 doesn't have it, it's from .60 onwards. Edited February 23, 2021 by GrimReaper76
