FredMuppeteer 13 Posted September 22, 2020 Posted September 22, 2020 So happy to see this in the web app now! I mainly need it for android/chromecast, is that on the horizon ? 1
Luke 42246 Posted September 22, 2020 Posted September 22, 2020 8 minutes ago, FredMuppeteer said: So happy to see this in the web app now! I mainly need it for android/chromecast, is that on the horizon ? Yes it is. 1
Malmgren 17 Posted September 23, 2020 Posted September 23, 2020 16 hours ago, Malmgren said: I've upgraded to 4.5 now and tried this, seems to work. My first question though is if there are any hotkeys to control this? Kinda cumbersome going into the menu every time. I don't think you spotted my question above, @Luke, are there any hotkeys? Especially important in the clients which you normally control using a remote control, you don't want to go five clicks into a menu to adjust the subtitle.
tattoomees 2 Posted September 23, 2020 Posted September 23, 2020 only works on webapp not on android ? When it be available on android players?
Luke 42246 Posted September 23, 2020 Posted September 23, 2020 12 minutes ago, tattoomees said: only works on webapp not on android ? When it be available on android players? HI, it will be in upcoming updates. thanks.
cyruspy 5 Posted September 24, 2020 Posted September 24, 2020 On 9/14/2020 at 12:44 AM, Luke said: This will be in Emby Server 4.5. You'll be able to use the controls in the video player to adjust the subtitle offset. Excellent!, will the Video file+subtitle file+offset combination be kept/remembered after alignment? 3
Luke 42246 Posted September 24, 2020 Posted September 24, 2020 4 minutes ago, cyruspy said: Excellent!, will the Video file+subtitle file+offset combination be kept/remembered after alignment? No, but that's something we can look at adding.
Dibbes 515 Posted September 27, 2020 Posted September 27, 2020 On 9/24/2020 at 6:51 PM, Luke said: No, but that's something we can look at adding. if an SRT/TXT, you could write the new time offset directly to the file 1
miniliQuid 95 Posted September 28, 2020 Posted September 28, 2020 (edited) On 9/25/2020 at 7:44 AM, Luke said: More goodies for subtitle fans: Awesome Edited September 28, 2020 by miniliQuid
caalin 67 Posted September 30, 2020 Posted September 30, 2020 (edited) @Luke I already wrote about this in a thread about the android beta, but can we have a per user global setting for subtitle delay? The reason is that all official subs are ahead by about 0.5 secs, which is extremely annoying, and it would get very tiresome to change the offset for every video This setting would be stored along with the other global subtitle settings (language and mode) and, now that the players support the offset, it shouldn't be difficult to simply apply it to every sub Also, if, in the future, you implement remembering the subtitle offset in the database, it shouldn't apply to this setting, only to those manually selected by the user Edited September 30, 2020 by caalin
Luke 42246 Posted September 30, 2020 Posted September 30, 2020 2 minutes ago, caalin said: @Luke I already wrote about this in a thread about the android beta, but can we have a per user global setting for subtitle delay? The reason is that all official subs are ahead by about 0.5 secs, which is extremely annoying, and it would get very tiresome to change the offset for every video This setting would be stored along with the other global subtitle settings (language and mode) and, now that the players support the offset, it shouldn't be difficult to simply apply it to every sub Also, if, in the future, you implement remembering the subtitle offset in the database, it shouldn't apply to this setting, only to those manually selected by the user I would suggest creating a feature request topic so that we can track this individually. Thanks.
Frode 1 Posted October 1, 2020 Posted October 1, 2020 I'll second the request for hotkeys. Also, I would like to have a setting for subtitle offset steps. In my experience, adjusting the subtitles in 500 ms intervals is suffciently accurate and a lot easier to sync correctly on the fly. 1
bernsy 3 Posted October 18, 2020 Posted October 18, 2020 When will this be available for the samsung app?
Luke 42246 Posted October 18, 2020 Posted October 18, 2020 2 minutes ago, bernsy said: When will this be available for the samsung app? It's already in the usb version.
bernsy 3 Posted October 18, 2020 Posted October 18, 2020 Oh thanks i didnt know that but thats precisely the version i use. Ill update my app then.
Luke 42246 Posted October 18, 2020 Posted October 18, 2020 Just now, coldviber said: and for android? 1
bernsy 3 Posted October 18, 2020 Posted October 18, 2020 (edited) I just installed new version and it works great! Well done! I do have an improvment suggestion, adding possibility to adjust at 500ms and also that the adjustment be remembered for that specific video+subtitled Edited October 18, 2020 by bernsy
Luke 42246 Posted October 18, 2020 Posted October 18, 2020 Yes we plan to have it remember in future updates. Thanks for the feedback. 1
thedave1022 4 Posted October 27, 2020 Posted October 27, 2020 When will this be available for Windows PC - Emby Theater and Android TV? 3 1
GrimReaper 4905 Posted November 10, 2020 Posted November 10, 2020 On 10/27/2020 at 2:52 PM, thedave1022 said: When will this be available for Windows PC - Emby Theater and Android TV? Any rough timeframe on this? Thanks. Cheers
Luke 42246 Posted November 10, 2020 Posted November 10, 2020 Hopefully soon. We're going as fast as we can. 1
