grouik1er 1 Posted January 16, 2016 Posted January 16, 2016 Hello, I just reinstall my Win10 and reinstall Emby. I put my share located on a synolgy, scan the library, all is ok. I test a movie it play fine. So i decided like always to start Emby by Services in automatic mode. Then no library access anymore, i have administration interface but scanning library is broken, no browsing movie, no picture. I restart Emby with AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe All is ok again.... So starting Emby with services broke library Access. Any idea ? Thanks server-63588572737.txt
Luke 42186 Posted January 16, 2016 Posted January 16, 2016 You need to make sure the account the service runs under can access your media. Or just keep it simple and stick with the tray icon version.
grouik1er 1 Posted January 16, 2016 Author Posted January 16, 2016 I change the "local system account" that start "EMBY Service" by default with my local admin account. It fix the problem but i never have to do this before. Thanks
