ebr 16343 Posted February 14, 2014 Author Posted February 14, 2014 One thing I am not a huge fan of how the custom list works is going backwards. Rather than automatically selecting the item that was just backed out of, it always defaults to the first unplayed in the list. Which for big collections with a lot of episodes can mean it scrolling up hundreds of episodes. I think it would make more sense for it to just back out of the episode details page and leave the episode that you were just viewing as the selected one. That's a bug. Shouldn't be doing that.
ebr 16343 Posted February 14, 2014 Author Posted February 14, 2014 And its a bug that is going to be very tricky to fix. Just for my information, why do you navigate to the detail screen normally?
blade005 185 Posted February 14, 2014 Posted February 14, 2014 ebr, I have toggled OFF the SHOW END TIME feature for all views in Chocolate, backed all the way out of MBC and re-started, yet the END TIME continues to be shown for all views. Am I missing something?
ebr 16343 Posted February 14, 2014 Author Posted February 14, 2014 Only the List view doesn't appear to respect the setting. I just tested with CoverFlow, Poster, Thumb and Strip and none of them show it if turned off (no re-start is required).
blade005 185 Posted February 14, 2014 Posted February 14, 2014 Only the List view doesn't appear to respect the setting. I just tested with CoverFlow, Poster, Thumb and Strip and none of them show it if turned off (no re-start is required). ebr, Ah. That's my issue. I have a large TV and Movie collection and find List View most effective for quick navigation.
moviefan 187 Posted February 14, 2014 Posted February 14, 2014 And its a bug that is going to be very tricky to fix. Just for my information, why do you navigate to the detail screen normally? I click on it and then click play to start the video...
ebr 16343 Posted February 14, 2014 Author Posted February 14, 2014 I click on it and then click play to start the video... You can just hit the Play button on your remote from the list...
hettar987 0 Posted February 17, 2014 Posted February 17, 2014 Hi, I just wanted to thank you for adding customization options, especially the ability to view the full backdrops in coverflow view. Thanks a lot for the theme !
AlwinHummels 134 Posted February 17, 2014 Posted February 17, 2014 (edited) Thanks for this great free theme but I have one question is it possible to choose witch icon to use on ex. the genre lists / poster view I prefer the thumb icon above the folder. but can't figure out how to use this. If it is not possible now to choose can you pleas add it to a future release :-) thanks a lot. Edited February 18, 2014 by AlwinHummels
moviefan 187 Posted February 17, 2014 Posted February 17, 2014 (edited) You can just hit the Play button on your remote from the list... I honestly didn't know that. But there is no way I will be able to train the wife and others this as well. They are all very simple people that understand to hit the up, down, left, right, select keys and that is about it. Anyway, not a big deal, just a minor annoyance I was pointing out. Edited February 18, 2014 by moviefan
trusselo 225 Posted February 17, 2014 Posted February 17, 2014 (edited) I dont even use a remote, took me years to find out about the "play" button, however luckily, my keyboard has media keys (play/pause stop next prev). Never thought to use them before, now i do alot. I even programmed some of the buttons on my razer naga mouse to be play/pause next ect when MCE is open. Programmed my dads mouse the same way. Edited February 17, 2014 by trusselo
mentasm 43 Posted February 18, 2014 Posted February 18, 2014 I think the majority of people will play from the detail view rather than from the list view. It is the most intuitive way and the only way that has a play button to visually select.
ebr 16343 Posted February 18, 2014 Author Posted February 18, 2014 I think the majority of people will play from the detail view rather than from the list view. It is the most intuitive way and the only way that has a play button to visually select. For me, it is much more intuitive to hit the play button from the list of items. This is the same way movies work from any other view as well. I actually rarely go to the detail screen for anything anymore now that so much information is presented in CoverFlow and the new TV view. While there is no visual cue, I think every single DVR works this way so people should be used to hitting a play button from a list of items to play that item. But, either way works. 1
CBers 7558 Posted February 18, 2014 Posted February 18, 2014 I think the majority of people will play from the detail view rather than from the list view. It is the most intuitive way and the only way that has a play button to visually select. I do as well - it's habit. 1
ebr 16343 Posted February 19, 2014 Author Posted February 19, 2014 Thanks for this great free theme but I have one question is it possible to choose witch icon to use on ex. the genre lists / poster view I prefer the thumb icon above the folder. but can't figure out how to use this. If it is not possible now to choose can you pleas add it to a future release :-) thanks a lot. There is currently no option to select which image to show other than primary or banner.
AlwinHummels 134 Posted February 19, 2014 Posted February 19, 2014 There is currently no option to select which image to show other than primary or banner. Thanks for your reaction, are there plans to make this possible in a future release?
ebr 16343 Posted February 19, 2014 Author Posted February 19, 2014 Not immediately, but I may look at it later. It will depend on how much impact it has on the layouts and how much work it is to add the configuration option. 1
AlwinHummels 134 Posted February 19, 2014 Posted February 19, 2014 Not immediately, but I may look at it later. It will depend on how much impact it has on the layouts and how much work it is to add the configuration option. Thanks Ebr no hurry ;-) other things are much more important
philman84 3 Posted February 22, 2014 Posted February 22, 2014 Well done on the update, looks like lots of hard work, visually it looks neat and its a nice new take on things with some of the features you added and im sure many many others will think its great. Me personally I guess im kinda stuck in my ways and was pretty happy with how things were before, it was just simple clean and just easy to use. Its just one opinion so dont take it to heart too much. Is there anyway apart from installing a new theme to have TV Episodes and seasons appear just the way they were before hand in the earlier version? Id still love to see that as an option as there was nothing wrong with it.
ebr 16343 Posted February 22, 2014 Author Posted February 22, 2014 I don't know what you mean by "appear just the way they were before" but there is an option in the config to turn off the specialized TV view.
philman84 3 Posted February 23, 2014 Posted February 23, 2014 I don't know what you mean by "appear just the way they were before" but there is an option in the config to turn off the specialized TV view. Ah thank you, yes found what you mean, order has been restored happy wife happy life.
ebr 16343 Posted February 26, 2014 Author Posted February 26, 2014 FYI - for those of you who have series with tons of seasons in them, the next version of MBC will fix the jump in list functionality so that you can just type in a number on your remote and this view will scroll to that season number. 3
