Xzener 729 Posted January 13, 2016 Posted January 13, 2016 Hey guys, Has anyone tried this?? I'm assuming a plugin would need to be built in order to control this type setup. Basically, it would be the same as what the Xbox One does. I would be interested to pick someone's brain about this type of setup. I would probably have to run ir blasters to my server in order to change channels. I has seen 2 channel capture cards, as well as 4 channel. It would be neat to have a TV guide and be able to record and change channels. Anyone knowledgeable in these cards??
SHSPVR 125 Posted January 13, 2016 Posted January 13, 2016 Xzener, on 12 Jan 2016 - 6:46 PM, said: Hey guys, Has anyone tried this?? I'm assuming a plugin would need to be built in order to control this type setup. Basically, it would be the same as what the Xbox One does. I would be interested to pick someone's brain about this type of setup. I would probably have to run ir blasters to my server in order to change channels. I has seen 2 channel capture cards, as well as 4 channel. It would be neat to have a TV guide and be able to record and change channels. Anyone knowledgeable in these cards?? There is another way of change channels on DirecTV STB via ethernet Both SageTV and NextPVR support it.
