AZRichG 10 Posted January 11, 2016 Posted January 11, 2016 This has happened on occasion to me. Something happens overnight that I can't nail down. The last interaction I had with Emby was to do some playback on my iPad which shows it disconnected at 9:34. Perhaps there is something going on with the guide refresh as its progress is showing 27.1% and not changing. For grins I loaded up the guide in a window and the next few hours are there as usual. FWIW the computer doesn't seem to be affected, except that the spare cycles aren't going to F@H. When I quit and restart everything goes back to normal where Emby uses 1.1% at idle. Attached are a couple screen shots and a log. I zipped the log as it was too large. Let me know if there's something I'm missing or a setting I should toggle, I am still very new to Emby. Rich log.txt.zip
Luke 42237 Posted January 11, 2016 Posted January 11, 2016 Hi, welcome. I don't see the guide refresh being run in this log. Can you please try to run it again, then provide the log from that timeframe? thanks.
AZRichG 10 Posted January 11, 2016 Author Posted January 11, 2016 (edited) Sure Luke. I see in the log prior to the one I posted this info- 2016-01-11 07:56:12.1139 Info HttpServer: HTTP GET http://localhost:8096/emby/LiveTv/GuideInfo. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_2) AppleWebKit/601.3.9 (KHTML, like Gecko) Version/9.0.2 Safari/601.3.9 2016-01-11 07:56:12.1167 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 3ms. http://localhost:8096/emby/LiveTv/GuideInfo Would it be good to post this log? That's easy enough. I'm using a 'save link as' and then compressing the logs, if there's a better way to post them let me know. Edit- Log110 is the one that clipping came from on the 10th Log110.txt.zip Edited January 11, 2016 by AZRichG
